Results 1 to 4 of 4
Thread: Starting problems
    Sep 2006
    NE, AR
    1,570
    Starting problems
    Got it all back together finally, just one problem. It cranks and will get the occasionally fire but no run.
    Using all my old ignition hardware except for the Cam sensor/unit.
    Battery low/bad or something else? I can get it up to about 12.6 but drops and if try to crank and a few tries (about 30secs) drops to 11.75-12.0
    Sep 2006
    NE, AR
    1,570
    Was a weak battery.
    Now it will start but sounds awful. Hear squalling metallic sound and what sounds like a loose nut in the bell housing area. Will run for about 10sec make this noise and then stop.
    No codes.
    Another question, My oil pressure gauge is reading 0 when running (have and Autometer gauge in A-pillar, though it pegs out w/ key in Acc position), does the Autometer guage require its own sending unit or is the OEM good? My orginal engine had a non OEM sending unit and I left the OEM one on the donor engine.
    Dec 2006
    106
    Yes, the oem sender and "gauge" is actually just a pressure light. The sender simply gorunds or doesn't, it doesn't send any kind of variable signal out.
    Sep 2006
    NE, AR
    1,570
    Well got it "running" but only ~25PSI on the oil.
    Now am I just looking at a non-primed system (my last motor I didn't prime and it ran just fine), a bad pump or restricted pickup; or is there something else that causes low pressure?
    Would low oil pressure make that noise too?
  1. SC at mechanic, having starting problems, please help?
    By ERamos in forum Technical Forum
    Last Post: 05-23-2004, 03:36 PM
  2. Extremly Bad Starting Problems
    By NATES93S/C in forum Technical Forum
    Last Post: 01-07-2004, 11:52 PM
  3. Urgent:Cold Weather Problems with Starting and AOD
    By swissboy97 in forum Technical Forum
    Last Post: 12-20-2003, 09:41 AM
  4. Starting problems and cutting out while driving
    By Hoss in forum Technical Forum
    Last Post: 11-01-2002, 01:39 AM
