Page 1 of 14 1234511 ... LastLast
Results 1 to 15 of 210
Thread: SC finally going back together
    May 2003
    Omaha, Nebraska
    6,207
    Took the day off to get as much done as possible. Cam is in and the heads all torqued down. Got the exhaust hook up. While I had the radiator out I polished the top to get it back to looking good. Gotta read up on the cam sensor and setting the rockers. I am using the stock rockers & push rods. Any techinacal help is always appriciated. Doing the work by myself and it is the first cam install I have done
    Memphis, TN
    1,911
    If I remember correctly, depending on the grind you may have to use slightly longer push rods.
    May 2003
    Omaha, Nebraska
    6,207
    Quote Originally Posted by Pablo94SC View Post
    Cam is a mild grind and can use stock pushrods and rockers according to Dave Dalke. More concerened with making sure cam sensor is set correct and rockers are also.
    Ken
    Blair, Nebraska
    3,257
    Did you get everything all buttoned up? Or still have a few loose ends to take care of?
    Fired it up yet? I'm interested in hearing it now compared to before
    -Melon
    May 2003
    Omaha, Nebraska
    6,207
    Quote Originally Posted by Melon View Post
    -Melon
    Mothers day kind of slow me down. Wife said No way was I working on the car on her day . Got a lot done Sat. I still have to align the cam sensor. Front accessory brackets, lower intake & supercharger. I plan on working on it tonight and will be getting close after today, to fire it up. I dont want to wait till just before the tune to get it running, in case I have a few problems to work out. I guess I dont really expect it to sound a lot diffrent except maybe at wide open throttle
    Ken
    Nov 2005
    Fort Wayne, Indiana
    2,985
    Quote Originally Posted by kenewagner View Post
    When you tighten the rockers down, make sure sure that particular valve is in its closed position so your torque specs arn't skewed by spring pressure.
    my email
    May 2003
    Omaha, Nebraska
    6,207
    Quote Originally Posted by mywhite89 View Post
    I readed up on the threads on rocker adjustment and setting the cam sensor. So I will be sure to check torque with the valve shut. I have less than a week untill my tune appointment so I have to have it running and all the bugs worked out before than
    Ken
    Nov 2005
    Fort Wayne, Indiana
    2,985
    Ken
    Where are you getting your tune done?
    my email
    May 2003
    Omaha, Nebraska
    6,207
    The dyno is in Lincoln NE. Dave Dalke tuned my car the first two times on this dyno. The owner of the dyno is a SCT dealer so he has all he needs to tune burn a new tune on my chip. There are several dynos here in Omaha that I could go to but I wanted to continue tuning on the same Dyno so I can get an accurate comparsion. There might be a diffrence in the guy doing the tune but the dyno is the same so I can compare apples to apples mechanical wise.
    Ken
    Aug 2002
    3,660
    Is that a little bit of dirt I see?
    Boston, MA
    7,356
    Good luck. Cant wait till the week ends to see the results.
    What do you guestimate the HP increase will be from the heads and cam combo alone?
    May 2003
    Omaha, Nebraska
    6,207
    Quote Originally Posted by Toms-SC View Post
    Engine was'nt that beautiful under all the bling. Took me hours to clean the grease and grime off the front of the block and the fire wall needed some cleaning as well. Its is much cleaner now. You have such a sharp eye Tom
    Ken
    May 2003
    Omaha, Nebraska
    6,207
    I dont know for sure what the HP increase will be for just the cam and heads. I was hopeing for 300 RWHP or better with the stock heads and cam at 19 to 20 lbs of boost from the big blower. I beleive the removal of the last restrictions to air flow will make for dramatic increases of torque and HP. A lot of mods I made to the engine prior to these heads and cam should start to kick in. I enlarged the lower intake inlet and plenum and install big 21/2" mandrel down tubes. All those mods netted me nothing for increase in power. In fact Dave Dalke at the last tune he did, said the exhaust was to big for the stock block and probably not helping any performace. With the new blower pushing out 7 extra LBS of boost, big valved heads and a better breathing cam, Daves new valve springs and 60lb injectors, I am thinking that 350RWHP is a good estimate for the tune. Anything over that would be iceing on the cake. 350 RWHP will make for 112 RWHP over the last tune Dave did. I dont think that is over estimating and should make for a fun ride.
    Ken
    Aug 2002
    3,660
    Ken
    It is all about the details.
    NYC
    17,431
    Cant wait to hear the results!
  1. I finally got one! Now what?
    By AlanEdwards in forum Technical Forum
    Last Post: 07-01-2005, 01:38 AM
  2. Finally get the car back:)
    By Lugen in forum Technical Forum
    Last Post: 04-19-2003, 10:44 AM
  3. Back up and running
    By 94scnflt in forum Super Coupe Club of Southern California
    Last Post: 04-15-2003, 11:24 AM
  4. FINALLY!! i got my sc back today
    By HappyHourHero in forum Non Technical Forum
    Last Post: 10-03-2002, 12:17 AM
  5. Got my blower apart finally
    Last Post: 07-15-2002, 07:37 PM
