Results 1 to 7 of 7
Thread: what is this connector in trunk?
    Dec 2004
    2,004
    i need to find out what this connector is for.....if you cant tell its in the truck drivers side. It comes out of the bundle of wires that are attached to the keyless module.
    Its a 2 prong male connector.
    Sry about the pics my camera isn't to great. pics are of the keyless box, also the interia switch is there just to give an idea where im at here.
    Feb 2006
    1,964
    It looks like the connector used to program remotes. What color are the wires?
    Dec 2004
    2,004
    Quote Originally Posted by birds4us View Post
    2 wires are going into it......there both like a very light gray or white with yeloow stripe.
    note: its coming from the wire bundle from the front....not from the keyless box as i first stated.
    Feb 2006
    1,964
    The connector to program the remotes has wire colors grey/yellow and white/yellow. Are you having a problem you need help with?
    Dec 2004
    2,004
    Patrick, im not sure i have your number....i know i did...pm it to me anyhow
    Dec 2004
    2,004
    it has aftermarket remote system.....which is junk as far as im concerned, i have already yanked the fuses that work it.
    calling
    Oct 2006
    va beach,va
    2,584
    Birds4us is correct, You turn the key on, short the two pins together with a piece of wire, the locks will cycle, push a button on the remote you want to program, locks cycle again, turn off the key, locks cycle again and your done.
  1. trunk latch question....
    By skydivr7673 in forum Technical Forum
    Last Post: 03-12-2006, 03:10 PM
  2. Did Ford ever make a SC trunk spoiler ?
    By Yenko in forum Non Technical Forum
    Last Post: 11-08-2005, 09:05 PM
  3. Need trunk electrical connector
    By Fordz Coupe in forum Super Coupe Club of Ontario
    Last Post: 09-11-2002, 04:31 PM
  4. car stereo in trunk.....
    By Scott-Atah in forum Technical Forum
    Last Post: 08-22-2002, 12:48 AM
