View Poll Results: Best BANG for the buck?
Voters
21. You may not vote on this poll
  • 4.6L DOHC Cobra engine
    12 57.14%
  • 3.8L SC engine/ MPX blown
    9 42.86%
Results 1 to 9 of 9
Thread: Best BANG for the buck? ...opinions wanted
    Ohio
    863
    Ok Guys...
    As you can see by my signature, I am currently rebuilding a 1990 SC. I currently do not have much in the motor rebuild save for some block prep (about $400).
    My question is this...
    Which motor gives the best bang for the buck:
    A. 4.6L DOHC Cobra Motor (with blower...I want to keep it blown)
    B. 3.8L SC engine with MPX blower (ported heads, cam, etc.)
    My goal for the car is to have a car that can perform both on a road course as well as at the strip. I'm hoping for 11's in the 1/4 mile, and the ability to have it perform well at SCCA.
    -Josh
    Apr 2004
    sumter, south carolina
    3,051
    oh without a doubt the cobra motor. more potential too.
    i think the 2004 SVT Cobra motor had 390 hp.
    with MPX, cam and heads (with exhaust and instake stuff) on the 3.8 i think u'd be around 350 hp
    Jul 2006
    Escondido CA
    468
    Quote Originally Posted by thunderkid84 View Post
    I aggree I think the cobra motor has more to offer than our 3.8
    May 2004
    Bmore
    3,228
    I disagree, if you are talking about your SC. There is no way the swap from the 3.8 to the 4.6 is the best bang for the buck. You adding weight with the additional cost of setting the car up for the 4.6. Just buy the MPX and supporting mods and go.
    Apr 2005
    Nor Cal
    2,976
    The 4.6 DOHC has way more potential than the 3.8. It depends how resourceful you are with picking up parts needed for the swap. To take full advantage of the MPX, you'll want to have your heads ported, cams, etc .. its going to cost $$$, the cobra is also very expensive. I would suggest picking up a 4.6 car to do the swap in ( or use your 97 bird !!! ), they can be found for very cheap .. you'll need more parts to swap from the 3.8 to the 4.6 versus going from a 4.6 SOHC to the DOHC - in which case, most people are going with the Aluminum block explorer PI 4.6 which can be had for very cheap and is a very easy swap for the 96/97 Birds.
    As far as the weight mentioned, I believe the 3.8 iron block with all of the SC parts and accessories, brackets, etc etc .. is quite heavy. Compared with the DOHC 4.6 or the explorer 4.6, they both have aluminum blocks and a nice vortech kit or the AED doesnt add that much weight to the overall package and will make plenty of power.
    Either way, getting into the 11's is going to cost $$$$
    - Dan
    Ohio
    863
    Well the nice part is that the SC is completely apart...and when I say completely, there isn't any wiring, fenders, doors, trunk, noting. It is just the uni-body sitting on jack stands at the moment. As far as the SC block, Like I mentioned, All I have done is basic block prep for forged pistons so it has been bored and honed, as well as hot tanked, and magnafluxed to check for cracks. So All I have in the SC is basically about $400-$600. So I have not spent a LOT yet. I figured that I would have about $7-10K in the power train alone by the time I was done.
    As far as the 97LX Sport, I'm wanting to keep that one as my DD, and I don't want to do much to her. The SC was always the project.
    Apr 2007
    Woodstock Ga
    1,772
    For the extra headache not sure the HP that you will get is worth it. I guess a lot would bepend on your HP/TQ goals.
    Get one of each!
    May 2003
    Omaha, Nebraska
    6,204
    Wow resurrection of the dead
    Ken
    93 SC Whipple powered 11.648 @ 119.6
    Twin Turbo, air intercooled..yet to see
    Apr 2007
    Woodstock Ga
    1,772
    Wow thats funny
  1. New Year - New Projects - Opinions Wanted
    By Ira R. in forum Non Technical Forum
    Last Post: 01-12-2005, 01:27 AM
  2. Biggest bang for the buck mod i should do next?
    By Jayls5 in forum Technical Forum
    Last Post: 10-17-2004, 10:57 PM
  3. bang for the buck? 95 blower ?
    By lowflying90 in forum Technical Forum
    Last Post: 03-11-2003, 01:05 PM
  4. Opinions on FordChip wanted........
    By z90sc in forum Technical Forum
    Last Post: 02-24-2003, 01:30 AM
