Page 1 of 6 12345 ... LastLast
Results 1 to 15 of 84
Thread: My finished FMIC project w/ *PICS*
    Apr 2004
    sumter, south carolina
    3,050
    heres my setup. just posting this for ppl making their own custom FMIC setup (and for comments on mine ). so they can get an idea for what they wanna do.
    i went with an intercooler off ebay, dimensions are 20"x12.25"x3.5". it was almost a perfect fit in there, i didnt have to do any cutting. just used some brackets, nuts and bolts from lowe's. cost $225 shipped.
    for the tubing i bought some various bends. 2mm thick and 2 of each : straight, 90*, 75*, 45*. came with 6 silicone couplers and 12 t-bolt clamps. i only used 2-45's, 1 straight and one 75. but i did have to buy 2 45* silicone couplers to finish it up. cost was about $140 shipped.
    finished it up by slapping the fan from my stock IC on there. 8" 800CFM. i also grinded down the return plenum flange so it would take a coupler and took the collar nut off the sc top.
    scale of 1 to 10 i would say it was a 6. just a little bit of ingenuity had to go into it.
    let me know what u guys think. i'll be glad to answer any questions about your own projects too.
    -Jason
    May 2004
    Va. Beach,Va.
    7,133
    i bought the same i/c and piping kit so your install gives me ideas on what i'm gonna do. the install looks good, i just don't like using 90 degree couplings because they collapse under boost. let us know how good of a job it does.
    SCCOA Member #2406
    '94 SC AUTO - 2.3 Whipple
    May 2007
    181
    Quote Originally Posted by nickleman60 View Post
    they wouuldnt collapse under boost. IF anytthing they'd expand. but if you have three or four ply you should be fine
    May 2004
    Va. Beach,Va.
    7,133
    Quote Originally Posted by f2tmx6 View Post
    i beg to differ with you, a while back when quick35th installed his liquid to air i/c his video showed them collapsing almost flat.
    SCCOA Member #2406
    Oct 2006
    48125,michigan
    4,185
    nice setup man i just dont wanna go this route..
    Aug 2002
    3,669
    Your going to want to do something about that hot air intake.
    Madison, Ohio
    17,665
    Looks great! Not sure how well that IC will perform though.
    Email me here.
    Oct 2006
    48125,michigan
    4,185
    Quote Originally Posted by Toms-SC View Post
    oh i want a front mount no matter what just not the route he went is what i ment..
    Nov 2004
    butler pa
    1,926
    under vacuum they can collapse, especially while the engine is decelerating. but under boost they are pressurised. and can not collapse.
    https://www.youtube.com/watch?v=7bNS...e_gdata_player 10.070 video
    Best ET to date 10.070
    Best MPH to date 130.51
    best 60' to date 1.312
    MPX blower/ NO NITROUS!
    May 2004
    Va. Beach,Va.
    7,133
    why do you say that?
    SCCOA Member #2406
    Apr 2004
    3,050
    I kinda see where you're coming from.
    i talked to Dave N. about this IC and he said he knew mustang's with the same setup and they were making big hp #'s.
    May 2007
    181
    Quote Originally Posted by Kevin Leitem View Post
    thats what i'm saying. if they're collapsing under boost there's issue's. i'm not unfamiliar to f/i vehicles at all,haveing had five of them. i've seen the stock rubber hose's on my probes intercoolr expand greatly under 16lbs. i've yet to see anything collapse under boost though,i'd like to see this video
    May 2004
    Va. Beach,Va.
    7,133
    Click to see Video
    not sure if i paste the video right... you were right, at vacuum they collapsed
    SCCOA Member #2406
    Apr 2004
    48183
    3,934
    dave what are your opinions with this setup
    can it produce 350 rwhp?
    Madison, Ohio
    17,665
    Quote Originally Posted by TwoToneThunder View Post
    His setup should be good for about 250rwhp. A short run IC isn't typically enough for an eaton at high boost and his motor is otherwise pretty much stock.
    Email me here.
  1. Finished the FMIC Project This Weekend (Pics)
    By CMac89 in forum Non Technical Forum
    Last Post: 08-31-2012, 08:42 AM
  2. Finished Head Gasket Project
    By txsc in forum Non Technical Forum
    Last Post: 01-16-2008, 09:47 PM
  3. FMIC project GONE POOPY!
    By xThunderbirdSCx in forum Technical Forum
    Last Post: 05-10-2006, 01:21 AM
  4. Oklahoma SC Project Finished (56K Beware)
    By OzzManG149 in forum Non Technical Forum
    Last Post: 05-23-2004, 04:09 PM
  5. just finished a little project
    By blown96bird in forum Non Technical Forum
    Last Post: 03-20-2004, 12:18 AM
