Results 1 to 15 of 16
Thread: O.E.M. Starter Relay
    Feb 2005
    Republic of Texas
    2,577
    Thought I'd bring this up again in case someone has run across a relay in the past few months...
    I am looking for an OEM starter relay for my 89 SC. The original is inop, and I have installed an aftermarket piece for the time being. The replacement piece needs to be functional, have the correct P/N (E9TF-11450-AA), be date coded to my vehicle assembly date, and must be in excellent cosmetic condition, comparable to my original (see attached photos).
    The date code, shown in photo 4, is P9E8; which decodes as follows:
    P = Design level
    9 = Year (1989)
    E = Month (May)
    8 = Day (8th.)
    I will take date codes from P9E4 - P9E12. This is within an acceptable production window for my car build date.
    As a bonus, if anyone can tell me the significance of the "A2" following the date code, I'd appreciate it. I assume it describes the production line and shift, but can't decide if it means:
    A = 1st shift
    2 = Line 2
    -or-
    A = "A" Line
    2 = 2nd. shift
    For my purposes, it's not important what these two characters read on the starter relay you have.
    Thanks,
    JD
    Feb 2006
    Columbia,S.C.
    502
    pm sent
    S
    Feb 2005
    Republic of Texas
    2,577
    >>>>>>>>>>>>>>>>>bump^
    Feb 2005
    Republic of Texas
    2,577
    If anyone has an 89 parts car, take a look and let me know what you have.
    Thanks,
    JD
    Feb 2006
    Columbia,S.C.
    502
    JD
    Ive got them as I mentioned but nowhere near the external looks that I am guessing you want.
    As I said Ill be happy to send a few you way but they are a little grungy (sp?)
    Phil
    Feb 2005
    Republic of Texas
    2,577
    Quote Originally Posted by shadow357x2 View Post
    JD
    Phil
    What are the date codes? Also, I'm looking for something that will clean up like my original, pictured above. As long as the base plate is in good shape, the rest should clean up.
    JD
    Feb 2006
    Columbia,S.C.
    502
    Quote Originally Posted by txsc View Post
    JD
    I'll check my stash tomorrow and let you know.
    S
    Feb 2005
    Republic of Texas
    2,577
    Dredging this thread up one more time. Maybe someone has come across a relay per my request in the last few months...
    Thanks,
    JD
    Dec 2003
    Connecticut
    2,217
    if your stuck on the original why can't you take it somewhere and get it fixed?
    Jul 2007
    Washington
    703
    I will check later today or tomorrow to see if I have one with the correct code. -Evan
    Feb 2005
    Republic of Texas
    2,577
    Quote Originally Posted by x182dan View Post
    If you have a source that will rebuild my original, I'd LOVE to have the contact information. That was my first choice, but I was unable to locate a service.
    Thanks!
    JD
    Feb 2005
    Republic of Texas
    2,577
    Quote Originally Posted by '90 SC View Post
    Thanks for checking.
    JD
    Feb 2006
    1,964
    JD, I have a relay but it is not quite the code you were looking for. It ia a P9C15A1. I will check my other car later this weekend.
    Feb 2005
    Republic of Texas
    2,577
    Quote Originally Posted by birds4us View Post
    Thanks for the response. That's the closest date I've found so far. After you check your other one, let me know which date is closer, and shoot me a couple of photos. I'll P/M you my email address.
    Thanks!
    JD
    Apr 2007
    New Orleans, LA
    1,957
    its just a relay!
    why not get a new relay and use the current relay housing? or you can even paint the numbers on the new relay??
    I don't get the point.
  1. Ford 'cheaps out' again...
    By Kit Sullivan in forum Technical Forum
    Last Post: 10-17-2007, 05:05 PM
  2. Continued ABS woes (and others)
  3. Power Distribution Box / Starter Relay
    By Dahoopd in forum Technical Forum
    Last Post: 06-13-2006, 11:37 AM
  4. Need help locating starter relay
    By Zimpster in forum Technical Forum
    Last Post: 02-14-2005, 12:02 PM
  5. starter fuse or relay?
    By lowflying90 in forum Technical Forum
    Last Post: 08-30-2004, 12:10 AM
