Results 1 to 8 of 8
Thread: got some small questions
    Feb 2007
    San Jose CA
    28
    What good product can I use to make my weatherstrip stick on good?
    when replacing the plastic on the hinge how much is the bolt supposed to be torqued to?
    How can I take these dents out my car?
    Clear Lake, Houston
    1,198
    Dents are not easy.
    As for the weather stripping. I take a junk piece and cut about a 2" piece and put it where they come together. It will not sag no mo.
    Jul 2007
    83
    wheatherstripping
    i'd try some 3m spray adhesive (it probably won't take much).
    Sep 2002
    298
    Try dry ice...
    It does a nice job pulling small dents like those, especially if they're not creased. Just hold a piece right on the dent, it will shrink the metal back into shape.
    Just make sure to wear proper protection Safety GOGGLES and insulated rubber gloves.
    Oct 2004
    Charlotte, NC
    8,159
    3M spray adhesive should work on the weather stripping.....
    My FSM says to tighten the bolt to 24 - 33 lbs ft.....
    Whatever that means......
    As for the dents in the door, I just replace the doors on mine when they get too bad, but I will try the dry ice trick.....
    You might be able to push the dent out that is under the side moulding from inside the door.....
    Oct 2002
    Covington, WA
    491
    Winnipeg, MB
    38
    Quote Originally Posted by HI-OUTPUT View Post
    I have questions of my own. Where did you get the plastic for the hinges. My Ford dealer told me they were not available anymore. Also, how did you get at the nut to keep it from falling when you removed that bolt to put the plastic on?
    Clear Lake, Houston
    1,198
    The "nut" is captioned. It doesn't fall out. And You can get the plastic in the help section of your local fill in the blank auto parts store. Or just get the whole bolt with the plastic on it.
  1. Bought a SC, sort of, and have a couple questions
    By Bobnova in forum New SC Owner Forum
    Last Post: 02-26-2006, 10:51 PM
  2. Replies: 1
    Last Post: 10-11-2005, 11:57 PM
  3. "What if I do this..." - Stupid Questions on the Rise
    By 93SuperCoupeBoy in forum Non Technical Forum
    Last Post: 06-21-2005, 09:39 AM
  4. Just a few Questions???
    By layinthesmack31 in forum Technical Forum
    Last Post: 05-05-2003, 05:22 PM
  5. "DON" questions...questions...questions
    By 1FlyBrd in forum Super Coupe Club of Greater New York
    Last Post: 01-05-2001, 01:56 PM
