Results 1 to 6 of 6
Thread: Question about suspension
    May 2007
    38
    Im going to be replacing the struts/shocks on the front and rear.
    Im reading over the installition and it says to discard the spindle to uppercontrol arm bolt and nut... alright but where do I find a new bolt and nut?
    I replaced the balljoint/control arms about a year ago and they are fine so do I reuse the bolts/nuts or what?
    May 2007
    Wichita, KS
    3,018
    the nut shouldve come with your upper control arm kit.. you should be able to reuse it.
    May 2007
    38
    yea I got the bolt/nut when I replaced the control arm Last year... but to remove the struts , the instructions say to discard that bolt/nut and replace it.
    Im just curious to see if I have to discard it and if so where would I get a new one
    May 2007
    Wichita, KS
    3,018
    shouldnt have to. i actually just reused the one that was on there before when i did my UCA's... you only torque them to like 70-75.. its not like head bolts.
    Dallas, TX
    5,745
    I reuse mine.
    Jan 2003
    Columbia, SC
    3,468
    Minor point but MN12's do not have struts...coil over shocks on the front. Shocks in the rear. The front suspension is a SLA (Short ,Long Arm) system.
    22 year SC Owner GFP
    (Glutton for Punishment)
    1992 5 Speed SC one of 1256
    1995 5 Speed SC one of 574
  1. Question on 89 suspension
    By Chris89 in forum Technical Forum
    Last Post: 02-04-2005, 10:56 AM
  2. Suspension question
    By green73 in forum Technical Forum
    Last Post: 02-03-2005, 03:02 PM
  3. Suspension Question...
    By Blown_347_SC in forum Super Coupe Club of Ontario
    Last Post: 10-09-2004, 12:36 PM
  4. Mark VIII suspension Question
    By aplvlydrtybird in forum Technical Forum
    Last Post: 06-08-2004, 10:02 AM
  5. Suspension bushing question
    By phiBAT10 in forum Technical Forum
    Last Post: 09-10-2002, 01:35 AM
