Motor mounts.. yuck! If you’re going to do them do both. Check your tranny mounts to as it’s a good time to do them as well.
You'll likely get two to three opinions on this. I just did a set on a 95 without a lift. I put it up on stands and used a jack to lift the motor. I had to take off the upper exhaust, cowl, driver’s side exhaust manifold or header, and both accessory brackets to get at them if you do it the same way I did. Pray you don’t break any motor mount sub frame bolts. When I put it back together I put the mounts on the motor and then lowered it onto the frame.
I’ve also heard of people lowering the sub frame. If you got the tools to do it that way good luck as I hear there are alignment issues after assembly.
