Results 1 to 15 of 19
Thread: Anyone know of someone who can tune in Calgary?
    Jul 2007
    Calgary, Alberta
    43
    I need someone to tune my car in Calgary or somewhere close to it. I just wanted to get a good idea of anyone who might have SC experience. I just did the SC pulley and JS pulley with cold air, now my car runs like a ~~~. Anything over like 9 lbs. of boost and it sputters, very frustrating!! The head mechanic at a local ford dealership, went for a spin with me, he sais it just needs tuning for more fuel, any comments on his advice? Thank you....
    Jan 2003
    Columbia, SC
    3,468
    When was the last time you replaced pugs and wires? What gap and type of plug are you running? What brand of spark plug wires do you have? Any other mods we should know about?
    22 year SC Owner GFP
    (Glutton for Punishment)
    1992 5 Speed SC one of 1256
    1995 5 Speed SC one of 574
    Aug 2002
    3,669
    Plugs and wires
    If you need a tune get XR7 Dave to do a mail order tune and for the love of god do not take it to a ford dealership here, do your own work.
    Jul 2007
    Calgary, Alberta
    43
    I was at the ford dealership to pick up some plugs then I was on my way to get wires when that mechanic had suggested we go for a cruise. So he was the reason I did not replace the plugs and wires. Someone had suggested this before some motorcraft copper core somethings With a 45 gap? sound good? cause I could try that, just to eliminate the possibility.. Thanks guys!!
    Lakeville, MN
    13,517
    When you did the cold air system did you hook the PCV hose back up that comes from the driver side valve cover, under the supercharger snout, and hooked up to the intake tube after the MAF? If not you could be letting too much unmetered air into the system.
    It really sounds like a boost leak or vac leak somewhere.
    Jul 2007
    Calgary, Alberta
    43
    Quote Originally Posted by Mike8675309 View Post
    The thing is, I put the cold air on quite a while before everything else and the car seemed to work fine. So I'm going to try the plugs and wires, Just need some Advice on what to run, and what to gap to.
    Jul 2007
    Calgary, Alberta
    43
    Hey,
    Ive done alot of spark plug jobs on our cars, if you still sport your AC and factory IC tubing, its best to do your plugs from under the car, should take hr to 2 hours complete, I ditched the AC for performance reasons and ease of the plugs from the top I can do plugs in 25 mins heh.
    The 2 plugs Ive used in the past and never have had problems with are:
    Motorcraft double platinum spark plugs
    stock replacement AWSF 34 PP, $8.96 each plus taxes.
    Motorcraft copper core spark plugs colder for high boost applications,
    equivalent to Autolite 103 AGSF 22 C, $3.09 each plus taxes.
    If your not looking to change plugs often Id stick with the 34pp's, and gap them to .045, the stock gap on our cars is .054, at 11 pounds of boost, with a 10% im sure your seeing more like 14 pounds of boost, id drop it down to .045, now with the other plugs i listed, they are very performance oriented, but require yearly replacement, and I gap these at
    .035, but im running 17.5 pounds of boost.
    hope that helps.
    Bruce
    Sound about right?
    Ps. thanx Bruce
    Jan 2003
    Columbia, SC
    3,468
    If no other mods...low side of stock gap I would recommend.
    Feb 2007
    Washington state, Tac
    395
    fresh plugs and wires can do wonders
    steve
    Jul 2007
    Calgary, Alberta
    43
    Sorry Duffy, you mean the copper core's and just run the 54 gap?
    Jan 2003
    Columbia, SC
    3,468
    I'd run the double plat stock plugs and go with the low side reading which I thought was .52 with the stated OEM range being .52 to .56.(At least that is what I remember) Assuming again you are stock except for cold air and OD pulley. And new plug wires and DO NOT use Jacobs wires. I use Accel 9000's and have no issues with them.
    NYC
    17,432
    Definitely sounds like a plug issue. The extra boost seems to be causing spark blow out. Copper plugs are great to use you just need to change them more often as our ignitions wreak havoc on the plugs.
    Tell us what happens after the swap. The Denso IT20's are Iridium and a tad colder then stock (1 step I believe) which isnt all that bad with the extra boost you have. I have run those with 21psi, the Accell 9000 wires and an da stock coil with no blowout. They reccomend not to regap as they are factory set by Denso and teh electrode is very delicate. I never regapped an dliek I said no problems at 21psi
    Lakeville, MN
    13,517
    Bruce,
    review this thread:
    http://www.sccoa.com/forums/showthre...ghlight=APP764
    It has information from various folks on plugs to use and gaps to go with. 54 or tighter should work fine for a gap.
    Feb 2007
    395
    the Accell 9000 wires are a good set of wires ,their 2nd on the list of wires to have ,at least in my book ,approx. ,150 ohms per ft. ,what part number were they...
    MSD 8.5's came up 1st at 100 ohms per ft. ,their web site says 50 ohms a ft.
    I ended up with the Borg/warner select SuperMags CH8651 (46.00) ,they rated at 300 ohms a ft. ,with a set of XP 5144 IRIDIUM (5.99ea.) ,set at 045 ,they run out strong with 12lbs boost
    steve
    Madison, Ohio
    17,676
    I would not use a stock type plug with more than stock boost. Detonation tendencies will be reduced with a shorter tip plug like the APP764. APP103's are a colder heat range and are OE replacments for Cobra's and Lightnings, just to give you an idea.
    Email me here.
  1. To Tune or Not To Tune
    By birdofprey in forum Technical Forum
    Last Post: 02-18-2005, 04:34 PM
  2. Anyone looking for a custom tune?, Dyno Tune with Jerry W. of SCT
    By MickeyD LX50 in forum Super Coupe Club of the Southeast
    Last Post: 04-30-2004, 09:27 PM
  3. FordChips Dyno Tune, San Diego CA
    By Lonnie in forum Super Coupe Club of Southern California
    Last Post: 09-24-2003, 09:23 AM
  4. FordChips Dyno Tune, San Diego CA
    By Lonnie in forum SCCoA Events
    Last Post: 09-18-2003, 09:08 PM
  5. Dyno Tune this Friday at Carlisle!!
    By kuhnga in forum Non Technical Forum
    Last Post: 05-26-2003, 04:24 PM
