Results 1 to 2 of 2
Thread: Stuck Injector?
    Las Vegas, NV
    125
    Stuck Injector?
    Gents, #5 spark plug is sooty with dry black, powdery deposits. Idle is excessively lopey and hydrocarbons off the chart. Thinking stuck injector. Any way to check pulse, resistance, etc? to determine? Thanks
    larry
    Lakeville, MN
    13,517
    Cylinder balance test part of the self diagnosis with a code scanner. You could check for a voltage on the control wire to the injector, but I'm not sure what scale you would use.
  1. Help, Injector leaking, seal or cracked??
    By Jogi in forum Technical Forum
    Last Post: 07-16-2006, 03:31 PM
  2. What Clip = What Injector
    By Dahoopd in forum Technical Forum
    Last Post: 06-11-2006, 12:57 PM
  3. Fuel pressure vs. Injector flow rate
    By Slysc in forum Technical Forum
    Last Post: 06-21-2005, 10:47 PM
  4. Speedometer stuck
    By bman1985 in forum Technical Forum
    Last Post: 03-09-2004, 12:42 AM
