Results 1 to 6 of 6
Thread: pinging bad
    Oct 2005
    oregon
    461
    pinging bad
    the coupe is a pinger not sure why!! idles @ around 20 psi I have done a leak test cant find any vac leaks. new plugs Double plat, new wires, run only super gasoline, get max boost of 8-9, new belts, SC makes no un healthy noises Im baffled what gives? any suggestions?
    Apr 2004
    sumter, south carolina
    3,050
    maybe try a can a fuel injector and systme cleaner ?
    seafoam worked great for me.
    Oct 2005
    oregon
    461
    Good thought I'll try some sea foam
    Joisey Jim Guest
    When did you last change your fuel filter ?. I had that problem on just my '93 5 speed (my '90 5 speed and '94 auto were no problem) and had to change the filter every 15k instead of 30k - strange but it worked, just very sensitive to fuel pressure. You might also make sure your knock sensor is connected, although I would think you'd get a CEL.
    Jun 2006
    163
    Could also be clogged cats. If you rap them with a rubber mallet and you can hear loose chunks inside, then they are bad.
    Jan 2003
    Roswell, Georgia
    594
    An interesting test would be to pull the Octane plug and see if you still get pinging. (Octane plug is located at passenger side firewall)
  1. 89 SC mabey bad DIS?
    By funkbuster in forum Technical Forum
    Last Post: 07-09-2007, 07:41 PM
  2. Bad Relay Causes Low Fuel Pressure...
    Last Post: 11-12-2006, 01:05 PM
  3. bad bad week
    By mannysc in forum Non Technical Forum
    Last Post: 06-13-2006, 06:55 PM
  4. No Codes, Violent Bucking, Bad MPG, lost!
    By Phil04 in forum Technical Forum
    Last Post: 06-07-2005, 05:53 PM
