Results 1 to 4 of 4
Thread: AOD swap
    Apr 2007
    Oak Glen Ca
    51
    AOD swap
    Can I swap an AOD from a 92 merc Grand Marqiuis 4.6 into my 90 3.8 SC?
    May 2007
    Wichita, KS
    3,018
    isnt the GM a FWD? and the 4.6 has a diff bolt pattern. you should look for a tbird, coug w/a 5.0 same bellhousing pattern. bolts right in.
    Jul 2003
    Eastern (nee Western) PA
    4,993
    No, the Grand Marquis is RWD, same as the Crown Vic. The Lincoln Continental has been FWD for a while.
    However, I think that you are correct about the bolt pattern for the 4.6. It would require some more investigation at the very least.
    You can use an AOD from the older Grand Marquis with the boxy styling and the 5.0 V8. My current AOD is from a 1989 Grand Marquis 5.0.
    God bless!!!
    Former Birds:
    Mar 2003
    Edmonton, Alberta Canada
    3,055
  1. 302 swap kit. Complete with Lentech clone AOD
    By V8Supercoupe in forum Parts for Sale
    Last Post: 01-20-2006, 04:12 PM
  2. SC AOD - 5.0 AOD swap
    By tbird50sport in forum Technical Forum
    Last Post: 06-23-2003, 09:13 AM
  3. 1990 aod tranny swap for 1993 aod
    By creeperxr7 in forum Technical Forum
    Last Post: 04-22-2003, 05:42 PM
  4. 5 speed to AOD swap (info needed)
    By Dustin Yenny in forum Technical Forum
    Last Post: 10-15-2002, 06:34 PM
