Results 1 to 5 of 5
Thread: 4.2 crankshaft in a SC?
    Jan 2007
    St. Cloud, Minnesota
    155
    ive done the research on v6power and allfordmustangs. im just wondering what you all think. yes or no and why.
    Oct 2004
    107
    ARP STUDS for the heads is needed
    I had a short block done and a guy was gonna buy it but it's still at the machine shop .
    Oct 2002
    Moorpark, CA
    1,246
    Quote Originally Posted by 90SC BIG BLOCK View Post
    As should be a requirement for all 3.8 SC's. There was recently a thread with some information that you may find useful:
    http://www.sccoa.com/forums/showthread.php?t=93071
    1990 Anniversary 5 speed: Built 4/90
    Motor is finally in and it is ALIVE!
    1990 Anniversary 5 speed parts car. Built 2/90
    Sep 2007
    303
    Thumbs up
    I would say yes as other people have tuned it with much more torque(which you need for the weight of these yachts)But, You need someone that knows what there doin.
    Milford, Michigan
    1,398
    I found a good deal on a good 4.2 crank and bought it for an engine that I'm currently building up. I thought I would cut down the tops of the stock SC pistons, use the stock 3.8 rods and then just rebalance. Turns out the 3.8 rods are too short and the piston skirts hit the crank counterbalances by about .160" (too much to cut). So I looked into the 4.2L rods/pistons but I don't trust the 4.2L rods. They look pretty weak even compared to the stock 3.8L rods. So then I looked into a 6.125" or 6.2" 351w rod but to find ones that have the correct wrist pin diameter, I was looking at $400. Then I would have to buy a good set of 4.2L pistons and rebalance. I decided that it was more money than I wanted to spend for .4L of displacement and 2 additional points of compression. So I'm just putting it back together with the stock 3.8L guts. Anyone want a 4.2L crank? I could put together a balanced assembly with forged H-beam rods, sealed power 4.2L pistons for $950 or I'd just sell the crank to best offer.
  1. Please help! Broken crankshaft?
    By gator2000 in forum Technical Forum
    Last Post: 06-23-2005, 05:46 AM
  2. Crankshaft Pulley Problem and Solution
    By RonzSC in forum Technical Forum
    Last Post: 06-18-2005, 04:18 PM
  3. 1990 TBird SC - Loose crankshaft - Central Florida
    By Goodman in forum Cars for Sale
    Last Post: 12-27-2004, 02:09 AM
  4. Crankshaft pulley, alternator, and accessory belt?
    By birdofprey in forum Technical Forum
    Last Post: 03-26-2004, 06:14 AM
  5. 4.2 Bottom End Project Continues
    By Kevin Keenan in forum Technical Forum
    Last Post: 06-30-2003, 07:15 PM
