Results 1 to 7 of 7
Thread: Still no tack
    Jun 2007
    Whitby On. Canada
    979
    Still no tack
    I have made some more progress and the car is running great. I still have no tack and my buddy that has the code reader is out of town and I will not be able to use it. Does anyone know which sensor or wires off the coil send the signal to the tack? I have tried changing the coil pack and same problem.
    I have also traced the wires and can't find a problem. I am trying to keep the car from a visit to Canadian Tire for a 100 $ diagnostic. If I can get my tack working I think she is ready for a trip down the strip.
    Any help would be appreciated.
    Drew
    Jun 2007
    275
    I accidentally disconnected the tach when I removed the ECM in the passenger kick panel. There was a brown connector that got loose.
    Jan 2003
    Roswell, Georgia
    594
    Fergus, Ontario, Canada
    1,972
    Drew, replace your Cam sensor, it will fix it.
    Apr 2006
    55
    Try cam sensor, it worked for me.
    Mar 2003
    Niagara NY
    2,535
    There's a gray wire with a rectangular black connector near your DIS harness. If that's disconnected your tach won't work. I found mine was disconnected after I installed a new cam sensor and my tach wasn't working. In my case, the black connector was broken so I had to tape it up.
    May 2004
    Bmore
    3,228
    Not sure what year yours, mine is a 93. There is a connector under the carpet right below the radio where the console bolts up. I diconnected it when I replaced my carpet and it killed the tach.
  1. Can You!!
    By super89 in forum Technical Forum
    Last Post: 03-08-2005, 06:53 PM
  2. remote start trouble!
    By duanemyhre in forum Technical Forum
    Last Post: 06-29-2003, 02:44 PM
  3. died on me
    By kluxman45 in forum Technical Forum
    Last Post: 08-05-2002, 09:35 PM
