Thread: Pulley size information please
    Oct 2002
    Lincoln, NE
    2,062
    I'm working on a personal project and need some information on the pulleys on the Super Coupe.
    Basically what I need is this: (I'm not worried about the accessories, just the supercharger drive information)
    Crank pulley diameter (stock to jackshaft):
    Crank pulley diameter (10% to jackshaft):
    Jackshaft pulley diameter (Stock from crank):
    Jackshaft pulley diameter (5% from crank):
    Jackshaft pulley diameter (10% from crank):
    Jackshaft pulley diameter (Stock to supercharger):
    Jackshaft pulley diameter (5% to supercharger):
    Jackshaft pulley diameter (10% to supercharger):
    Supercharger pulley diameter (94/95):
    Supercharger pulley diameter (89-93):
    Supercharger pulley diameter (5%):
    Supercharger pulley diameter (10%):
    Basically I'm working on a spreadsheet where I can enter some basic information and it will calculate the drive ratios of the supercharger. This is done more for custom applications like M112s, AR, etc so that you can get the right pulley combination for your engine requirements. I'm sure someone will be able to just say it's 2:1, but that's not what I want. I want to be able to calculate the ratio given a specific pulley size. So I need the pulley size information to build a table in order to extract the data. I would also prefer accurate measurements, not approximations. The more accurate the data, the better the calculator will be.
    Thanks for the information.
    Dec 2003
    Altoona IA
    3,237
    SuperXR7 started this one, but I've added quite a bit.
    SCCoA won't allow xls, so I uploaded the spreadsheet as a .txt. Download it and rename the extension back to xls.
    Attached Files Attached Files
    Oct 2002
    Lincoln, NE
    2,062
    Thanks...that gives me some of the information I was looking for. I still need the 5% and 10% pulley sizes for both the jackshaft and supercharger. I didn't see those on the chart.
    I'm doing something very similar to that spreadsheet, except more user friendly. I'm incorporating dropdown boxes, automatic fill, etc to make all the calculations. It will be available online as well when I'm finished. Right now it's still a work in progress, but it is getting close to being done.
    I've got things like gear ratios, max mph for a gear, cruising rpm, airflow requirements, compression ratio, displacement, etc...Most of the information I'm using is generic in nature, but there's going to be some that is SC specific. I'll post the link here when I'm done with it.
  1. Magnum Powers 15%-25% OD No-Slip Pulley kit Group purchase
    By XR7 Dave in forum Group Purchases / Specials
    Last Post: 07-10-2007, 09:57 PM
  2. Power steering pulley removal for novices
    By J.D. in forum Technical Forum
    Last Post: 05-12-2005, 04:35 AM
  3. WYNN check out my crank pulley
    By mannysc in forum Non Technical Forum
    Last Post: 05-08-2005, 12:56 PM
  4. Level of interest: Balanced Aluminum Crank Pulley Stock Size
    By white91sc in forum Non Technical Forum
    Last Post: 05-07-2002, 02:20 AM
