Results 1 to 7 of 7
Thread: Codes 172, 173...running rough
    Jul 2007
    Memphis area
    411
    I have a '95 SC that is running rough and the Check Engine light comes on. I pulled two codes, 172 & 173 with a code scanner. Any advice? I am thinking it is a sensor of some kind.
    Thanks!
    Ray
    Mar 2007
    East Lyme, CT.
    156
    Code 172, o2 sensor indicates lean, and 173 o2 sensor indicates rich, both bank 1. I had this a few weeks ago, just replaced O2 sensor, and its fine now.
    Good Luck,
    Brian
    Aug 2002
    Salisbury, NC
    81
    Same thing here I had those codes as well. My CEL would come on for a few seconds at a time every few minutes I pulled out the O2s and my right one was visibly covered with soot and the left pretty clean. I went ahead and changed them both for right under $100. The best price I found on them was at O’reilly auto parts and I think you have them in your area. Once I change them the light was gone and after the relearn the car runs great and improved my MPG as well.
    Jul 2007
    Memphis area
    411
    Fantastic guys! Thanks! I will get right on it!
    Ray
    Jul 2007
    Memphis area
    411
    Ok. I replaced both O2 sensors and seemingly cured that problem. Now the CEL comes on at random and the car sputters. The code scanner does not pull any codes. Any suggestions?
    Jan 2003
    Roswell, Georgia
    594
    Try disconnecting the battery to clear EEC memory from old O2 sensors.
    Jul 2007
    Memphis area
    411
    Quote Originally Posted by sail7seas View Post
    Yep, I did...no luck...dang it!
  1. Running Rough
    By ryan a harris in forum Super Coupe Club of Ontario
    Last Post: 06-11-2007, 11:39 AM
  2. Codes 172, 181
    By TBone95 in forum Technical Forum
    Last Post: 05-16-2004, 06:08 PM
  3. car running rough and ridiculous boost
    By MadMikeyL in forum Technical Forum
    Last Post: 02-20-2003, 01:27 AM
  4. Running codes
    By blksc in forum Super Coupe Club of Southern California
    Last Post: 01-13-2003, 07:40 PM
  5. Got it running, now many codes
    By Lewis in forum Technical Forum
    Last Post: 08-06-2002, 10:50 AM
