Results 1 to 2 of 2
Thread: IAC valve?
    Indiana, PA
    1,040
    IAC valve?
    where is the IAC valve and what does it do? what are the symptoms of one going bad?
    Thanks,
    Jeff
    GTA
    238
    It is located on the side of the throttle body. It is the black thing. It is what controls your idle and I beleive there is no adjustment for it. From all the syptoms I have read about, when your idle shoots up to 2000 + RPM's, chances are it is bad. Also, when you turm your car off, it can make the sound of a "dying goose"
    hope this helps.
    ps. IAC stands for Idle Air Control
