Results 1 to 6 of 6
Thread: Power Window Issues
    Apr 2006
    55
    Power Window Issues
    Hey people. I am having a weird issue with my power windows. They will go up and down fine while it is cool outside. Once it gets hot(around 80), the drivers side will stop working, and once it gets even hotter(round 90) the passenger side will stop working. Once it cools back off in the evening, they start working again.
    Sep 2007
    303
    What??????????
    Nov 2004
    Brantford, ON
    5,383
    I wouldn't be surprised that the "cams" inside the gear housing for the window drive assembly have pretty much crumbled to nothing and all your counting on is the grease inside.
    Ok, so that sounded confusing..... there is an article that explains how to pull out the power window drive assembly and replace those cams. I've had to do the same thing with mine, as mine acted exactly like yours did.
    Here's a good article, but you gotta be a member to see it.
    http://www.sccoa.com/forums/showthread.php?t=47986
    ps: Having a good beer moment! EEEeeehhhhhhh canadian beer.... I wonder what Homer would have done with Labatts Ice......
    Sep 2007
    303
    That's what I was gonna say. Easy job 16bux 20min
    Feb 2007
    Dallas
    296
    I had my passenger window that you couldn't even pull down with the motor trying too.
    If it was wet it would work, so I got some spray silicon and lubed the channels. It's been working great for a month now, figure if I have to spray them every couple of months, no problemo, should work fine for you too.
    Orem, UT
    5,902
    Quote Originally Posted by fturner View Post
    Labatt's: Best thing to ever come out of Canada. I love that beer!
    Change the motors, my car wouldn't work the drivers window when it was really hot. I replaced the motor and it's been fine.
  1. Attention Tim, power window delete
    By Kevin Leitem in forum Technical Forum
    Last Post: 07-22-2008, 04:24 PM
  2. Power window wiring ?
    By tydlwavs in forum Technical Forum
    Last Post: 04-03-2007, 09:17 PM
  3. Power Window Problems...
    By iwannanSC in forum Technical Forum
    Last Post: 04-29-2003, 10:39 PM
  4. Mass Buy On Power Window Glass-plastic Clips?
    By ReDevilXR7 in forum Technical Forum
    Last Post: 08-18-2002, 07:54 PM
  5. HELP!!!!!!!!! Power Window Motor
    By Les Borda in forum Super Coupe Club of Ontario
    Last Post: 05-28-2002, 05:43 PM
