Results 1 to 15 of 30
Thread: new owner of 1994 SC question about mods
    Oct 2007
    North New Jersey
    25
    I just got the car its a automatic performed full maintenance to the car
    new 180 thermostat
    new belts new idler pulleys and springs
    10% od crank pulley
    190 fuel pump
    mp cold air intake 3.5
    76mm mass air c&l
    mp supercharger top
    new plugs gapped to .030
    new wires
    new trans neutral safety switch
    intercooler fan
    afpr
    fpg
    any input would be great
    o and i have my own dyno to use a 224x dynojet
    Thanks
    George Benson
    Sep 2004
    Indy
    5,623
    Best modifications you can do are porting the supercharger, using some type of intercooler whether it's a Double Intercooler or a front mount, catless exhaust, ported heads and a cam, a converter, and 3.73 gears.
    Everything else is very minimal gains.
    Browse around a few performance sites:
    www.supercoupeperformance.com
    www.spinningwheels-sc.com
    May 2007
    Wichita, KS
    3,018
    you mean... a 94 sc? lol. a 2004?
    Oct 2007
    North New Jersey
    25
    I guess ill pick up a set of high flow 2.5 cats and a 3 dynomax ultraflow mufflers 1 duel in duel out and 2 singles and bend up a exhaust on my bend pack this weekend . Maybe that will give me something.
    May 2003
    Omaha, Nebraska
    6,204
    Some strange combinations you have. A 3.5 fresh air intake, 76MM maf, I assume a stock throttle body. Not very well matched. Porting the blower wont do you much good pulling air through a stock plenum and TB. The 10% will generate way to much heat and pull the timing on the top end even with a fan on the IC. The exhaust will do you a world of good and you should feel an improvement. The 180 degree thermostat wont do a lot of good unless you program the fan to come on sooner. You need a chip in the computer for that. The top will get you little to none improvement untill you get to a much higher level of HP.
    1 Exhaust
    2 Bigger TB and plenum
    3 Better IC with that 10% over drive
    4 SCT chip and tune
    These are the basics. If you want the biggest bang for the bucks
    1 An autorotor, if you can find one
    2 Cam and heads
    All kinds of bolt ons wont do what the cam and heads will do for you
    Ken
    NYC
    17,430
    For bolt ons you can go Magnum Powers inlet for SC and at least a 75mm TB. The S port charger or MPII would be a greaqt upgrade if you can find one...Or hav eyour charger ported
    The exhaust is definitely a restriction. The cat section and resonator have got to go.
    A nice tune will wake it up as well. Unsure what your best fuel pressure should be but that can throw things way off. Someone here will chime in for sure. You can do tweaking with the fuel pressure. 42lb lightning injectors can be had cheap and if going for a tune a good idea at this point..There will also come a tim ethat the 190lph pump will not do
    A nice converter 2400 stall and thw 94-95 autos have no trac loc..Youll want to get that>>>if you have a shop a nice gear swap would do wonders. 3.73 are good track gears with 4.10'a beig ideal IMO
    after all this..When you arent 100 % happy...A good head and cam package will make all teh difference
    Oct 2007
    North New Jersey
    25
    a 85mm throttlebody and a mp plenum are on the horizon. Just doing this slowly this is my beater car to get back and forth to work with. I spent to much cash on my vette this month so the beater will have to wait for some more mods. I currently have one of the fastest C6Z06's in the country. All motor 10.51@132 nitrous 9.94 138. built 100% by me. Currently the car has a 25.5 sfi certified cage good to 7.50 et and building a new 445ci nitrous motor to make over 1000 rwhp.
    George
    Quote Originally Posted by kenewagner View Post
    1 Exhaust
    4 SCT chip and tune
    2 Cam and heads
    Ken
    NYC
    17,430
    where are you located anyway?
    NYC
    17,430
    I'm imaginin that isnt the same zo6 I was fooling around with on the highway the other day haha
    Oct 2007
    North New Jersey
    25
    I am in nj and my car has been under the knife for 3 months now so if it was a couple months ago it could have been me mine is all white with carbon fiber canards on the front bumper
    George
    Apr 2004
    sumter, south carolina
    3,051
    Quote Originally Posted by 07WhiteDevilZ06 View Post
    George
    if thats the case then no need for an 85mm. 75mm will flow plenty.
    NYC
    17,430
    George,
    You have a dyno. DO you also do tuning? If not I may have someone for you.
    Let me know
    Oct 2007
    North New Jersey
    25
    Quote Originally Posted by DamonSlowpokeBaumann View Post
    George,
    Let me know
    yes I have a dyno and we do tuning on the ls1's but I dont have software for this car to tune it
    George
    May 2003
    Omaha, Nebraska
    6,204
    Quote Originally Posted by thunderkid84 View Post
    The 75MM is a perfect fit for a 3" intake tube but since you have a 3.5" tube and your going to up grade, get the big TB so you are matched.
    Ken
    Apr 2004
    3,051
    \but since you have a 3.5" tube and your going to up grade, get the big TB so you are matched.
    Ken
    ahh, forgot about that. well for a 3" intake and 76 MAF and 75 TB match up perfectly.
  1. 1991 sport, lots of mods
    By Screwloose in forum Cars for Sale
    Last Post: 06-04-2006, 03:54 PM
  2. Who figures out HP claims on MODS
    By Dahoopd in forum Non Technical Forum
    Last Post: 05-07-2006, 08:43 AM
  3. New 90 Owner (mods)
    By NastyEssCee in forum New SC Owner Forum
    Last Post: 03-18-2006, 02:57 AM
  4. New M90 owner.
    By rallystang in forum New SC Owner Forum
    Last Post: 01-06-2006, 12:07 PM
  5. mods & fuel economy
    By joenintiesc in forum Technical Forum
    Last Post: 07-23-2002, 04:43 PM
