Results 1 to 14 of 14
Thread: starting trouble
    Feb 2003
    El Paso Texas
    110
    starting trouble
    I bought an 89SC 5-spd,it has 102k miles. It has a new fuel pump,crank sensor,cam sensor,and tps.The engine turns over but does not start.We have single out every possibility and their is no injector pulse. The conclusion we have is that the factory alarm doesnt allow it.The previous owner removed it. The computer does not allow us to run the scanner in it. The theft light keeps flashing.Where can I find the alarm module???
    Apr 2004
    sumter, south carolina
    3,051
    how bout a bad ECU ?
    Feb 2003
    El Paso Texas
    110
    we've done that already,but no luck.The only reason why I brought it was because the car is in great shape and the interior is awesome,no cracks or worn out areas.I bought for a grand. The was not very familiar with car so he gave up trying.every bit of info would be helpfull. Thanks in advance
    Jul 2004
    Salt Lake City, Utah
    1,519
    The stock anti-theft module, which is located in the trunk behind a vertical black panel on the left fender, disables the starting circuit. It does not cut off the injectors.
    Is the IRCM applying 12 volts to the injectors?
    Feb 2003
    El Paso Texas
    110
    it turns out that it is the anti-theft module,but how can I by-pass it in order for the car to start????
    Jul 2004
    1,519
    Quote Originally Posted by notorious sc View Post
    If you are using the ignition key to operate the starter motor, then the anti-theft module has been bypassed, at least where starting the engine is concerned, because you stated that the engine turns over. If you are operating the starter motor directly from the starter relay on the left front fender, then the anti-theft should not interfere with starting the engine.
    You didn't say if the injectors have a constant 12 volts from the IRCM
    Feb 2003
    El Paso Texas
    110
    I believe so???But Ill double check tomorrow.Thanks for your info.
    Dallas, TX
    5,705
    Quote Originally Posted by J.D. View Post
    Umm.. The power to the injectors comes from the EEC itself. The IRCM switches power to 4 things: EEC, fan motor, and A/C clutch coil. Are you sure that's what you meant?
    I'd start with some simpler stuff first.. fuel pressure? Firing order correct? Tach moves when cranking ? Does the amber colored arrow on the tach go out when cranking? If the EEC isn't getting the PIP signal from the crank sensor, it would not pulse the injectors.
    Jul 2004
    1,519
    I understand that power to the injectors is through the IRCM while the return is through the EEC. The EEC switches the return on and off.
    I asked 'notorious sc' to check this because he said that there is no injector pulse. I know that there should be 12 volts at the injectors if the fuel pump relay works, but the car might have been rewired.
    Dallas, TX
    5,705
    OK. Good nuff. I've never heard of that problem before. Seems a bit odd. I would not want to try to figure out what was done if it was rewired.
    (hijack) On the IRCM subject, there are 3 physical relays in a "normal" IRCM and I assume 1 solid state for the A/C clutch coil. Does anyone know which is which?
    Feb 2003
    El Paso Texas
    110
    i get zero volts and i get zero pulse.Fuel pressure is their,new fuel pump,new crank sensor,new cam sensor,new tps,new fuel filter,harmanic balancer ok, fuel pump relay ok and all other relays that consist are good.Can a eec of a auto work on a 5-spd????Thanks alot for the info.
    Jul 2004
    1,519
    Did you check for 12 volts at pin 24 of the IRCM after you turned the ignition key on (no need to start the car)? This is the same as checking for 12 volts between one of the injector terminals and ground. The attached diagrams will help in finding easier locations for measuring this voltage (for example at the canister purge solenoid).
    If you're still missing 12 volts, then check the fuses for the IRCM (EEC and IG COIL).
    Feb 2003
    El Paso Texas
    110
    thanks alot,let you guys know how it turns out
    Jul 2004
    Hamilton NJ
    2,040
    Did you ever figure it out???
    I know this is old but nobody updates their post with an ending conclusion!!!!
    Tom Downs-member#2752
    MPX'd 90 SC Auto~bought Feb. 2012
    RIP MOM!!! I will always miss and think about you 4Ever! 1940-2018
    RIP Rexy boy!!!! Miss my dog 2006-2018
    http://www.sccoa.com/forums/garage_v...vehicle&id=424
  1. Trouble starting SC
    By Slydawg316 in forum Super Coupe Club of Eastern Virginia
    Last Post: 05-16-2006, 03:59 PM
  2. SC at mechanic, having starting problems, please help?
    By ERamos in forum Technical Forum
    Last Post: 05-23-2004, 03:36 PM
  3. Trouble Starting / Fixed !!!
    By Flip in forum Technical Forum
    Last Post: 07-30-2003, 07:38 PM
  4. abs pump, trouble, trouble, trouble.
    By heliarc in forum Technical Forum
    Last Post: 06-28-2002, 02:39 AM
  5. 93 SC auto trouble starting/ check engine light on
    By ecko1er in forum Super Coupe Club of Northern California
    Last Post: 09-22-2001, 03:03 PM
