Alternator issues
gearheadtoo
Have been having problems with the alternator in my 94 SC lately but after reading some of you guys posts it sounds like I'm not the only one. Mine charges normally (14.3 volts) when it is working but then quits charging while the car is being driven, usually within a day or two. I can get it to charge again by pushing on the electrical connector which plugs into the top of the alternator. I assumed the connector was bad and have replaced the end which plugs into the alternator but am still having the same problem. The connections on the alternator do not appear to be dirty or burned. Suggestions anyone?
