Results 1 to 15 of 21
Thread: what mass air to use with a mpx?
    Apr 2004
    48183
    3,934
    i just bought a 76mm mass air flow sensor for my car and i plan on running a mpx blower with 60lb injectors
    which mass air flow sensor would be the best? with a 76mm work or is it going to be to small?
    7,582
    Stock longblock, or do you have heads and cam going on as well? I'm running a 76 C&L with the MPIII, stock engine. You would probably want to go with the larger version if you're doing heads and / or cam too.
    cheers
    Ed N.
    Apr 2004
    48183
    3,934
    dave dalke heads package
    mpx blower 25% od
    mp front mount ic
    griffen radiator
    60lb injectors
    Apr 2005
    230
    80 or 90 mm
    there is a guy down in houston with a similar set up and he is running with a 80 or 85 mass air.
    Dec 2003
    Altoona IA
    3,237
    I'm running a 73 mm with an MPx and 50 lbs injectors.
    It really all depends on your application.
    Sep 2003
    P-Town, MN
    2,511
    My built block with 60lb injectors and an MPx was tuned with an 80mm C&L and was not close to pegging it.
    It's only impossible until we do it.
    22-year SC owner - '93 SC AOD (non-locking TC). Same car, same original paint!
    Current setup: 12.550 @ 111.09, 1.917 60ft, no bottle.
    May 2007
    St Louis MO
    1,222
    I have an 80mm....thats what Dave said would work..........on a side note post pics of all these new parts
    Apr 2004
    48183
    3,934
    Quote Originally Posted by pablon2 View Post
    what kind of power numbers did it put down?
    what are your other mods
    May 2007
    St Louis MO
    1,222
    Quote Originally Posted by TwoToneThunder View Post
    http://www.sccoa.com/forums/attachme...4&d=1195156689
    Nov 2004
    Brantford, ON
    5,383
    To put it this way, the 76 mm C&L MAF with the purple sample tube for 42 lb injectors can flow up to 2000 Kg/h of measurable air based on the stock electronics. In other words, the electronics will be sending a 5 volt signal once you are sucking in 2000 Kg/h of air through that MAF with that sample tube. (This is theory, because alot of things including how the CAI setup is done can alter those limits, and that can go either way.)
    There's an electronic limit as well as a physical limit you need to consider. Alot of folks are surprised how soon they can peg a lightening MAF using its electronics.
    So how much air in Kg/hr can an MPX overdriven at 25% move if the motor can use all that air going into it?
    Sep 2003
    P-Town, MN
    2,511
    Hmmm, let's see. It jumped off the dyno, then the XXIC split the top weld, and then we ran out of tuning time, AND THEN the thrust bearing went out, so I never got any numbers. Dam, I'm mad all over again.
    Sep 2002
    Effingham.IL
    5,011
    I don't know for sure ,but I am under the impression. That there
    is no sample tube for the C&L 76MM MAF that go's with #60 injectors.
    I thought that C&L had sample tubes to fit up to #50 injectors
    for the 76mm MAF.
    Randy
    NYC
    17,432
    Didnt come near pegging it with 318rwhp..We shall see what happens once the AR is thrown on
    NYC
    17,432
    You blew your motor or is it just that the thrust bearing is kinda shot..Ive noticed the thrust bearing being shot on alot of high mile SC motors that are still running
    Lakeville, MN
    13,517
    mpx blower 25% od
    mp front mount ic
    griffen radiator
    60lb injectors
    Just get one that fits in your budget. Start with asking your head provider his recommendation.
    Since you are getting a chip, that will adjust the fuel mapping to MAF voltages. you just want to make sure that your MAF is sized such that it provides a smooth proportional increase of voltage to air flow without hitting 5v before you take the foot off the pedal.
    I believe as far as value is today, the 80mm seems to be the no brainer, unless you are looking used.
  1. C&L 85mm TUNER mass air
    By XxSlowpokexX in forum New Products and Services
    Last Post: 04-25-2005, 01:08 PM
  2. WTB: 91-93 30# supercoupe mass air (70mm)
    By Darth_Menace in forum Want to Buy
    Last Post: 04-20-2005, 09:40 PM
  3. WTB: 30# or 36# supercoupe mass air (70mm or larger)
    By Darth_Menace in forum Super Coupe Club of Ontario
    Last Post: 02-22-2005, 03:39 AM
  4. Where is coy Miller's Mass Air meter
    By strokedsc in forum Technical Forum
    Last Post: 12-29-2004, 01:38 PM
  5. 2k idle think it is mass air sensor
    By baddabing80 in forum Technical Forum
    Last Post: 03-04-2004, 01:42 PM
