I have run into a problem with money and need to get rid of the car quick!
Lots of upgrades in the car done by the previous owner, I've only owned this car for three or four months and only put about 300 miles on it since I've owned. I dont know much of what was done to it, but this what I've been told
Upgrades:
engine rebuilt at 100K miles, now has 118K on it
44 lbs Injectors
high flow fuel pump,
underdrive and supercharger pulleys
throtle body, cold air intake
MAF sensor
Cam (not sure which one)
Cam sensor
high flow oil pump
Mustang cobra rear end 3.73 LSD
upgraded fan, new radiator
2500 Stall converter
super charger (replaced at the time of the rebuilt) is running just under 13 psi
New Built Heads (replace at 100K)
heavy duty gaskets
full exhaust from headers and all
I've been told by the previous owner that the engine was built to handle a 100 shot of nitrous,.....Im sure their is some stuff I forgot about
Only problem is, transmission has crapped out...... It is an AOD, 1st 2nd and 3rd gear are "built", 4th is blown...... I dont know what happend to it (havent had chance to jack it up), but I know all the fluid came out and was pretty burnt. possibly and trans line came off, or I cracked the casing... I'll try jack it up this weekend
Looking to get $3,300 for it....
Will get pics soon.
Located in Stamford, CT
Drop me an email at Nscott4130@gmail.com
Thanks,
Neil
Upgrades:
44 lbs Injectors
MAF sensor
Cam sensor
high flow oil pump
heavy duty gaskets
Will get pics soon.
Thanks,
Neil
