View Poll Results: Which Style Hood?
Voters
92. You may not vote on this poll
  • 3" Cowl Induction, pins on 4 corners
    7 7.61%
  • 3' Cowl Induction stock hinges, pin down front
    38 41.30%
  • Heat Extractor, pins on 4 corners
    4 4.35%
  • Heat Extractor, stock hinges, pin down front
    43 46.74%
Page 1 of 6 12345 ... LastLast
Results 1 to 15 of 85
Thread: Building molds for carbon fiber hood. What style hood?
    Milford, Michigan
    1,398
    If someone were to make a new mold for an SC hood and make carbon fiber hoods and fiberglass hoods, what style hood should they do?
    1. 3" Cowl Induction Hood, pin on 4 corners.
    2. 3" Cowl Induction Hood, stock hinges, pin down front.
    3. Heat extractor hood, pin on 4 corners
    4. Heat extractor hood, stock hinges, pin down front.
    5. Other
    Aug 2007
    San Jose CA
    378
    I would hate to get a 4 pin cornor for everyday use. Would be a hassle. But cant you make any aftermarket hood 4 pin
    Heat extractor hood would be nice. Would be a one of a kind on a bird for awhile.
    Or even a functional ram air hood.
    https://www.cervinis.com/large.aspx?...9,8030_820.jpg
    Sep 2006
    HARRINGTON DE
    1,193
    What might the heat extractor version look like?I vote for a bolt on style.And I've always loved the cobra r svo hood and wish someone made those for our cars.
    Jay
    Feb 2005
    KILLEEN TX
    933
    I would love to see one styled after the WS6 Trans Am. I love the quality and looks of the Cervini Mach 1 but it needs to be another inch and a half taller. Any of the hoods should use the factory hinges and latches. Lift off is too much hasle for a daily driver or if you are at any gas station and want to check your fluids, or break down. If you are by yourself it would be no fun trying to get a lift-off hood off your car without scratching it to hell.
    Milford, Michigan
    1,398
    The 4 pin style isn't too popular but we could do it with just one mold whereas to use the stock hinges we would have to build a mold to make an inner and another mold to make the outer, then laminate them together. Naturally that drives the cost of the hood up significantly.
    The heat extractor would be similar to the design that is available for the 03 Cobras. I'll get a graphic designer to draw one up.
    Sep 2004
    Indy
    5,623
    Heat extractor with pins on four corners.
    Hinges get in the way too much and a hood off of the car exposes more sunlight to see what you are working on and nothing is in the way.
    Sep 2006
    HARRINGTON DE
    1,193
    Yeah a heat extractor styled like the one for the 03 cobra that would be bad a**.I'd definetly be interested as long as it's not crazy expensive.
    Jay
    Jan 2005
    Pacoima CA.
    477
    Is this wishful thinking or someone is goingto make this? I like SCP inc's cowl hood but would like it to be 3.5 center rise!
    Jan 2004
    Outside KC MO
    5,791
    I would like to see some different designs than are currently available. I REALLY would like a Firebird style TA hood that is about an inch higher than the stock one, but I have to figure out what will clear the top on my blower before I commit.
    Chris
    Queens, NYC
    1,058
    Im in for a 3" cowl hood with 4 pin on's.. Heat extractor is just not the right look for the car but a 3" cowl will make the car look beefy as HeIl
    And this is a reality if enough people are interested.. A carbon fiber cowl hood will weigh probably less than 1/2 of what a fiberglass hood will..
    I know on my Talon the stock hood weighs around 50lbs.. And the carbon fiber is a little under 10.. Let me not get started on the hatch and doors (5lbs for the hatch and 15lbs on the doors)
    If anyone says Cobra R style hood I hope you come to Carlisle or the Shootout cause I will kick you in the nuts..
    Aug 2004
    KSRQ
    5,175
    3" cowl is too much. Need something a little more subtle, about half the height.
    Ira
    NYC
    17,431
    Coba R style!>>>Seriously though...What about 4/95 hoods?..Is that an option as well?
    Aug 2007
    Suffield, CT
    1,028
    Milford, Michigan
    1,398
    The pricing that I'm getting back preliminarily is saying that carbon fiber sheet is $50/yard. It's going to take 3 yards per layer for an SC hood. That's just the sheet. Then we've got resin, labor and the ammorization of the mold cost into the piece price (depending on the volume). I should have a pretty accurate per hood cost soon.
    Jan 2004
    Outside KC MO
    5,791
    Wow...we are looking at $450+ per unit by my estimate for a lift off hood then.
    Chris
  1. Building a "Summit" style catalog for SC owners
    By aviationstation in forum Technical Forum
    Last Post: 04-26-2006, 02:29 PM
  2. Need 94-5 style hood
    By pipecraze in forum Want to Buy
    Last Post: 11-05-2005, 04:08 PM
  3. Cobra hood 89-91 style
    By IdoXLr8 in forum Parts for Sale
    Last Post: 03-27-2005, 08:49 PM
  4. 96/97 style 3" fiberglass cowl hood
    By tydlwavs in forum Group Purchases / Specials
    Last Post: 05-09-2004, 07:59 PM
  5. MP style Carbon Fiber Intake @ $134.25
    By Nettlesd in forum Technical Forum
    Last Post: 04-22-2003, 01:19 PM
