Water pump too
seawalkersee
I had to tear the engine down because the intake leaked internally. I finally got time to do this tonight so I pulled the engine and tranny out of the car (mind you it has been sitting since 05!!!). Pulled the engine and M5 out as a unit and took the tranny off. Started taking off the front cover and saw that the impeller of the water pump had started cutting into the front cover. The pump is/was still good. Has anyone else had this happen? I have seen it before when the shaft or bearings go bad, but never when the pump is still working.
Chris
