Results 1 to 5 of 5
Thread: Warning Chime Module
    Feb 2005
    Republic of Texas
    2,577
    I need a known good warning chime module for my 89. The P/N is:
    E7DB 10D840-AA
    This is the module with the single-row connector. Advise cost shipped to 78154.
    Thanks!
    JD
    Norcross, GA
    3,308
    I found my chime module if you're still in need.
    Feb 2005
    Republic of Texas
    2,577
    Quote Originally Posted by Mike Puckett View Post
    Already got another one, and it turned out not to be the problem. Thanks anyway!
    JD
    Nov 2004
    Plano, Texas
    291
    I sure what to know what the solution is TXSC. Please post the solution.
    Feb 2005
    Republic of Texas
    2,577
    Quote Originally Posted by kpatton View Post
    Well, I really don't know if I'd call it a "solution" or not. Here's the thread from up on electrical:
    http://www.sccoa.com/forums/showthre...303#post705303
    The bottom line is that I could find nothing wrong with any of the components. But, after disconnecting everything for testing, and then reconnecting, the problem was "solved". It seems to be fine now. But, because I didn't find a discrete problem, I can't be too proud about fixing it. More luck than anything...
    JD
  1. Anyone know how the oil life monitor works?
    By MadMikeyL in forum Technical Forum
    Last Post: 03-25-2010, 05:00 PM
  2. ABS pressure warning switch questions
    By bigjoeroy in forum Technical Forum
    Last Post: 09-26-2008, 01:26 PM
  3. resetting keyless door pad?
    By obucina in forum Technical Forum
    Last Post: 08-31-2006, 03:00 PM
  4. New and need help
    By Garrard8 in forum Technical Forum
    Last Post: 01-31-2005, 01:43 AM
