Results 1 to 5 of 5
Thread: 96 lx electrical problem!
    Mar 2007
    Minnesota
    212
    I haven't driven my 96 lx for about 3 weeks and i drove to town today all is fine except the alt guage was really low at idle i didnt think anything of it. On my way how down the highway i smell burning wires didnt see anysmoke or anything and then my dome light started flashing really fast :lol: and i got home car reeks of burnt wires and the dash lights and the parking lights stayed on.
    Has this happend to anybody else:tongue: my car has remote start also i think that may have something to do with it. Anybody have some other good ideas where to dig in on this.
    Mar 2007
    Minnesota
    212
    I checked out the remote start all looks well no burnt wires. Could the light switch just of burnt out causing the dash lights and park lights to stay on?
    Jul 2004
    Salt Lake City, Utah
    1,521
    Quote Originally Posted by tim-g View Post
    ..................Could the light switch just of burnt out causing the dash lights and park lights to stay on?
    I think that's a good place to start. Unplug the connector/s to the main light switch and see what happens.
    Mar 2007
    Minnesota
    212
    I pulled the headlight switch out and it looks fine but the plug in is burnt what am i suppose to do about that?
    Jul 2004
    1,521
    A connector can melt for various reasons. A wrong fuse will allow the wires to carry excessive current, a nicked wire will heat up at the point where it is damaged, or arcing due to a poor connection will produce heat. Arcing can happen inside the switch or inside the connector if a wire was nicked when the terminal was crimped on. Depending on the materials used, arcing inside the switch could cause the connector to melt before the switch.
    Hers what I would do:
    1) Verify that all the fuses for the lighting circuits are the right amperage.
    2) Buy a new or used connector along with a short length of the harness and splice it into the existing harness. Check if Headlight Switch Pigtail 99-8317 is suitable at this site: http://www.source-products.com/publi...lpha_list1.htm
    3) Replace the headlight switch.
  1. electrical problem?
    By ZOOMBUGGY3 in forum Technical Forum
    Last Post: 10-23-2006, 07:20 PM
  2. weird electrical problem
    By Platinum90SC in forum Technical Forum
    Last Post: 08-26-2003, 01:02 AM
  3. Small Electrical Problem
    By SickWhip in forum Technical Forum
    Last Post: 05-28-2003, 12:16 AM
  4. Yet another electrical problem....
    By flyingunz in forum Technical Forum
    Last Post: 02-27-2003, 06:18 PM
  5. Electrical Problem
    By Heavy-Fuel in forum Technical Forum
    Last Post: 09-06-2002, 09:29 AM
