View Poll Results: What ECT has the best track record
Voters
3. You may not vote on this poll
  • ACDELCO Part # F1855
    0 0%
  • AIRTEX Part # 5S1140
    0 0%
  • STANDARD MOTOR PRODUCTS Part # TX6T
    0 0%
  • ACDELCO Part # 213756
    0 0%
  • MOTORCRAFT Part # DY681
    3 100.00%
    0 0%
  • FOUR SEASONS Part # 36407
    0 0%
Multiple Choice Poll.
Results 1 to 4 of 4
Thread: What Coolant Temperature Sensor (ECT) Sensor Brand is good
    Aug 2004
    2,024
    My fan is coming on late and I want to swap out the ECT. What's a good brand everyone's had luck with?
    Aug 2004
    2,024
    Forgot to ask, how much coolant really needs to be drained to replace this sensor?
    Jan 2003
    California city, CA.
    823
    None, just level the car & relieve the system pressure. you will see the coolant just sitting there close to the top of the collar. When installing I squeeze the upper rad hose so the coolant is at the top so the sensor gets liquid & not air.
    It would pressure up to it anyway but its a help.
    "Airplanes are interesting toys but of no military value."
    Major General Ferdinand Foch, 1911
    Jul 2003
    Eastern (nee Western) PA
    4,993
    I just recently read that it's a good idea to check the resistance of the IAT sensor against your ECT sensor to make sure that they both give approximately the same information to the EEC. (Best done off the car in a pan of water or something.) The temperature versus voltage scale should be the same. If they are too far off, consider replacing the IAT sensor as well.
    God bless!!!
    Former Birds:
  1. I found this FAQ on the SC
  2. Continued ABS woes (and others)
  3. Good Good Good...Good Injection..NITROUS
    By TBSCoupe in forum Technical Forum
    Last Post: 03-13-2003, 01:39 PM
  4. won't smog
    By gardenasc in forum Super Coupe Club of Southern California
    Last Post: 11-23-2002, 02:16 PM
