Thread: Engine Problem.... Need Help ASAP.....
    Edmonton, Alberta, Canada
    147
    My car will not cold idle at all..... I can even let my car stand for an hour, after really hard driving, come back and it will not idle...... And there are no codes.... Anyone have any ideas?.....
    Thanks in advance
    Straffordville, Ontario, Canada
    357
    PCV valve plugged?
    Idle air controller?
    Throttle position sensor.
    Maybe someone has a used item(s) you could try for trouble shooting. That way if it doesn't work it keeps the cost down.
    Poor fuel pressure? Plugged filter? Faulty pump.
    Plugged air filter?
    Mass air sensor....
    Vacuum hose off?
    Plugged exhaust system?
    147
    Thanks..... I'll try some of those
