Page 1 of 22 1234511 ... LastLast
Results 1 to 15 of 322
Thread: **My SC problems**
    Aug 2005
    Paoli Indiana
    4,622
    **My SC problems**
    When i go to start to start the SC it acts out of time.. cranks slow and acts like its trying to fire at the wrong time etc.. half to half floor it to get it to start then it runs like complete garbage for about 30 seconds and smooths out. So far ive tried the following.
    Battery
    Ignition switch
    Cam ~~~ sensor
    DIS
    Checked the timming its dead on spec
    Other parts i have:
    Coil pack
    Engine wirring harness
    Could i have possibly stabbed the cam ~~~ stalk wrong when i rebuilt it? would it make the car NOT run properly and act out of time and have no balls off the line?
    93 SC Red Auto 111k
    2013 Shootout Bracket ET First Place
    2015 Shootout Car Show Honerable Mention
    2016 Shootout Mod-1 First Place
    4.2, 2.3 Whipple, 3.73s AOD
    395rwhp 11.360 /??? mph
    90 SC 35th auto 84k
    Madison, Ohio
    17,583
    Quote Originally Posted by Jacob_Royer View Post
    Battery
    Ignition switch
    Cam ~~~ sensor
    DIS
    Other parts i have:
    Coil pack
    Of course it's possible you could have stabbed the CPS wrong. It has to be timed much like a distributor (only different). Do a search and follow the instructions. You starting problems are compounded by the fact that you have 40% bigger injectors and haven't done anything to correct for that.
    Email me here.
    Aug 2005
    Paoli Indiana
    4,622
    nope i still have stock injectors in it.. I see no reason why it should run so crappy.
    93 SC Red Auto 111k
    90 SC 35th auto 84k
    Madison, Ohio
    17,583
    Sorry, thought you had 42's in it. If you did not time the cam sensor then it can't run right.
    Email me here.
    Aug 2005
    Paoli Indiana
    4,622
    http://www.sccoa.com/forums/attachme...5&d=1210038875
    Is this what its supposed to look like at 26 atdc? (before i tear it apart)
    93 SC Red Auto 111k
    90 SC 35th auto 84k
    Aug 2005
    Paoli Indiana
    4,622
    Im going to try to get this cam ~~~ sensor deal checked out. Also changing the engine harness as some of the plugs are not in the greatest shape (cant hurt anything) And the blower swap and plug wires.. HOPEFULY this will get it to run right.. It just progresivily gets worse.. It got the the point of being almost undrivable.
    93 SC Red Auto 111k
    90 SC 35th auto 84k
    Dec 2005
    208
    Yep that's it.
    Aug 2005
    Paoli Indiana
    4,622
    I THINK i got it right the first time but.... i very well could have ben 180deg out or somthing...
    BTW i know the blower has isues since it only makes 8psi with a 5% blower and 5% js
    93 SC Red Auto 111k
    90 SC 35th auto 84k
    Aug 2005
    Paoli Indiana
    4,622
    I need to get it straightened out so i can drive it a couple weeks.. Need to do a clutch in the mustang and an OR H pipe while i have it apart.
    93 SC Red Auto 111k
    90 SC 35th auto 84k
    Aug 2005
    Paoli Indiana
    4,622
    Would the timming light verify correct timming at the chain?
    93 SC Red Auto 111k
    90 SC 35th auto 84k
    Mar 2008
    Rochester NY
    469
    If ya can Id try moving the cam sensor counter clockwise about an inch....If she turns over slow most of the time your timing is too far advanced....I time by ear..Might be why my cars are slw but thats another topic....I get the motor nice and hot and find where my car starts at its limits...
    Madison, Ohio
    17,583
    That alignment was correct, just make sure the motor is at 26' ATC on COMPRESSION when setting it. At 180 out I doubt that it would run.
    I'm starting to think that most of your problems might be related to the blower. The blower is a very tight tolerance and sealed component. It can't be just "tossed" together quick and be expected to work properly. I'm thinking you may be quite correct in your earlier assessment that the case was leaking and that may be your whole problem.
    There is no way to check timing of either the cam sensor or the crank sensor other than to follow the procedure for setting it. The ignition timing will always read 10 deg when checked according to procedure. It cannot be adjusted and it cannot be anything other than 10 deg.
    Email me here.
    Aug 2005
    Paoli Indiana
    4,622
    If the case leaks would it cause my starting/idle problems? like a giant vac leak?
    93 SC Red Auto 111k
    90 SC 35th auto 84k
    Nov 2002
    Williamsport, PA
    543
    Yes, any vacuum leak will cause bad idle problems. Even small ones will make it run like crap, at least from my experiences.
    NYC
    17,431
    I thought you were changing the blower?..Whjats your vacuum at idle at?
    Also what MAF did you use and its calibration..A mustang calibration is different then an SC in case you didnt alreayd know?
  1. spout timming plugs
    By stempak in forum Technical Forum
    Last Post: 02-17-2008, 11:43 AM
  2. Timing set
    By chadder1313 in forum Want to Buy
    Last Post: 04-26-2005, 04:17 PM
  3. timming degrees !help!
    By creeperxr7 in forum Technical Forum
    Last Post: 07-07-2003, 04:16 PM
  4. timming chain cover
    By ZOOMBUGGY3 in forum Technical Forum
    Last Post: 05-30-2003, 01:08 PM
  5. where can I get timming chain set on cammer
    By mannysc in forum Super Coupe Club of Southern California
    Last Post: 06-05-2002, 01:52 AM
