Thunder8289
Reseting Factory Keyless Entry
In order to reset the codes for the keyless entry fob, you have to look into the trunk.
There should be a module on the left side under the trunk matting by the fuel pump shutoff switch. You have to open that up and there should be two posts that are not connected.
You have to jump the gap with a paper clip or something, then the locks will pop up and down.
Press a button(any button) on the key fob and they should pop up and down again.
You have now reset the code.
I found this on another site and I was wondering if this means that you can change your code.I do not know the code for my keyless entry and the numbers are not in the trunk because the car was painted by the previous owner.Does anybody know how to program a new code if you don't know the old one?
