#106
Quote:
__________________
1994 5 speed-Who needs a MAF anyways! 0 RWHP--0RWT 0 @ 0mph http://www.sccoa.com/forums/garage_v...vehicle&id=110 |
#107
Time for the reserection. Who has had the mod done? Who can give some good solid numbers? Who cant give good solid numbers and just wants to talk more about it? Who can give a GOOD seat of the pants "Only mod I made and drove it again" feel?
Rich, What does your porting job consist of? Chris |
#108
Coy Miller removes the center triangle on his stage 2-3 engines. Coy did the porting on my intake and he removed the triangle inside the intake per my request. I had asked Coy to flow the intake before and after but he was unable to get it on the bench and back to me fast enough. As for before and after tests I have none. I have driven my project car with the intake but with all the other mods I cannot give an accurate response to doing just the intake mod. Single plane intakes traditionally do not have a air divider inside them. This OEM intake from Ford used on the SC is the first I have seen. As for just porting the intake Coy does this to all his engines. Gasket matching and porting will always promote better air flow. The term laminar flow is a result of smoothing the air flow across a surface. Laminar air always flows faster than turbulent air flow. I'm sure someone eventually will have a controlled before and after intake test.
Rich |
#109
Siiiiiiiiigggggggggggghhhhhhhhhh...another dead end...
...Oh well. Time to pull the spare engine outta the car.. Thanks rich Chris |
| Thread Tools | |
