#31
Finally using some of those parts I see.... looking good.
#32
if you have a free min, could you maybee put a parts list with part numbers up on this post. maybee it can be turned into an Install DIY.
thanks I have been throwing around this idea myself to swap my m5r2 for a t-56. What did you do about a drive shaft? |
#33
Not to take away from Dave's work....
......But search can work.
I listed a lot of part #'s in this thread for my swap. http://www.sccoa.com/forums/showthread.php?t=75969 MikeH p.s. Keep up the great work Dave! |
#34
and here...
Quote:
MikeH |
#35
This is pretty cool....looking forward to how this turns out.
#38
Hey Dave,
Have you tried shimming the pressure plate on the flywheel. McLeod told me a while back that I needed a shim ring to get the correct clearence for disengagement, but I am using a stock flywheel and pressure plate with their disc. Reason was that their disc is several thou thicher than stock. Don't know if this will help. Good luck, MikeH |
#39
Any update to this Dave?
-Corey |
#41
Not sure if this is helpful or not, but figured I would post it anyway:
http://www.streetlegaltv.com/news/mc...ntation-issues |
#42
I know the powertour is coming up, planning to wrap this up upon your return? Anxious to put something like this on my future to do list.
__________________
I neeed fuel.....and heads.......and cam........and supporting valvetrain modifications
#43
Gee, why could that be??? How many M5's you been thru now?
#44
Counting yesterdays, 3
__________________
#45
Ok, so finally got to drive the car yesterday. Went the roundy rounds on the twin disc clutch and still have some issues to resolve, but so far making good progress.
The stock SC master cylinder has too much mechanical advantage over the Mcleod slave cylinder. From my discussions with McLeod it seems that the desired master piston diameter is about .700" whereas the SC master is about .900. This means that we achieve full extension of the slave very early in the stroke and as a result the pedal is overly firm and doesn't travel all the way to the floor. I think the solution here is to get an adjustable quadrant from McLeod to increase pedal travel. If you were just into drag racing then this would be ok. You'd need to fabricate a pedal stop so you don't pop the slave seals, but it would be great for shifting quick, having only about 2.5" of pedal travel. The tranny shifts nice and the clutch is awesome. Spendy, but awesome. On an extreme build like this one I think this is the only way to go.
__________________
Email me here. |
| Thread Tools | |
| FUN FORD WEEKEND September 16-17 | MCA6SPEED | Super Coupe Club of Florida | 9 | 01-06-2012 01:33 PM |
| BBF and T56 swaps..alot to learn!!! | talonhead | Technical Forum | 39 | 10-05-2010 03:57 AM |
| Well.. weekend at St. Thomas was great for me | drummerzrok24 | Super Coupe Club of Ontario | 8 | 09-20-2006 11:09 PM |
| NMRA TV - Video of NMRA Route 66 All Weekend | nmrajames | Racing/Track Results | 0 | 07-27-2006 12:38 AM |
| Weekend at Sebring | Flip | Racing/Track Results | 3 | 04-28-2005 12:34 PM |
