Super Coupe Club of America Forums
Go Back   Super Coupe Club of America Forums > General SCCoA Forums > Technical Forum
User Name
Password
Register FAQ Garage Chat Search Today's Posts Mark Forums Read
Reply
Thread Tools Rate Thread Display Modes
  #1
Old 05-21-2012, 03:16 PM
Bluntz Bluntz is offline
Oil Gauge questions
1995 Body, 90 motor, 3.8 sc
As i am driving the oil gauge on the right side of instrument panel barely goes onto the letter N. Sometimes it doesnt touch the N at all. Is this normal? What should the setting be? If it isnt right then what do i need to do to repair?
Thx in advance.
  #2
Old 05-21-2012, 03:27 PM
90sc35thann's Avatar
90sc35thann 90sc35thann is offline
SCCoA Member
The gauge in our cars is really an idiot light. That said you can try a new sending switch (located by the oil pump and filter). If that doesn't work you can check your actual pressure by hooking up a temporary mechanical gauge. If it checks out then it is most likely the gauge and I wouldn't worry too much.
  #3
Old 05-21-2012, 05:59 PM
HelluvaEngineer HelluvaEngineer is offline
I'd spend the money on a real gauge. Mine moves all over the place. I believe it's just hooked up to a sender that has continuity if you have 7psi or something like that.
  #4
Old 05-21-2012, 06:25 PM
r1dd1ck913 r1dd1ck913 is offline
SCCoA Member
Or you could convert your stock gauge to a real gauge. Like this http://www.cardomain.com/ride/390762...oupe-2d/page-8
  #5
Old 05-21-2012, 07:26 PM
BirdofPrey97's Avatar
BirdofPrey97 BirdofPrey97 is offline
SCCoA Member
This and your water temp are related. Clean the wires, check them make sure they are not cut or bad in some way on both sendors. Tap the dash by each gauge and see if they read differently while the car is running and is warmed up.
__________________
Honor, Grace and Dignity......Remember these
  #6
Old 05-21-2012, 08:24 PM
sleeper bird sleeper bird is offline
SCCoA Member
i have been battling this for a couple of years,changed the sending unit a couple of times,hooked up a mechanical guage had great pressure,hooked factory guage back up very low pressure.Got pissed and hit the guage lexan cover and all of a sudden worked like new.Got another guage out of a parts car and really did about the same as the other guage.Its agitating because in my 95 a light comes on that says check guages.I wonder if you do this conversion if the light will stay off.If it will i am all over this conversion for sure.damn good idea.
  #7
Old 05-21-2012, 08:30 PM
SCCoA Member
so basically on the guage cluster you are doing away with the resistor right?
  #8
Old 05-21-2012, 09:16 PM
RalphP RalphP is offline
SCCoA Member
Quote:
Yep, and installing a real sending unit instead of the pressure switch that's there now.
BOTH are needed.
  #9
Old 05-21-2012, 09:27 PM
SCCoA Member
do you think the check guages light will stay on after you change the sending unit and do away with the resistor?
  #10
Old 05-21-2012, 10:54 PM
SCCoA Member
My check gauge light stays off unless I loose pressure.
  #11
Old 05-22-2012, 12:36 AM
SCCoA Member
You may want to put a mechanical gauge on that line first, and see what pressure you're actually GETTING.
If you have good pressure ( elsewhere there's math on how many PSI per 1,000 RPM with X oil - or maybe on TCCoA - or maybe on BobtheOilGuy.COM - somewhere! ) and if it then keeps acting up, I'd look hard at the anti-slosh board first.
  #12
Old 05-22-2012, 10:37 AM
David Neibert's Avatar
David Neibert David Neibert is offline
Administrator
Thx in advance.
The connection at the sender is probably loose. Just remove the sender wire and squeeze lightly with pliers and reinstall for a tighter fit.
__________________
91 SC AOD 4.2..2.3 Whipple........10.92 @ 126.70
93 SC AOD 347 Turbo.................10.04 @ 138.99
  #13
Old 05-23-2012, 06:24 AM
SCCoA Member
mechanical guage read 35 psi at idle.
Reply
Thread Tools
Display Modes Rate This Thread
Rate This Thread:
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Forum Jump
Thread Thread Starter Forum Replies Last Post
My day with an oil change and coolant leak. Questions inside. BlownSix Technical Forum 4 03-13-2008 03:58 PM
Low Oil Pressure.. gauge or oil? hayshane Technical Forum 3 07-18-2007 11:58 AM
Hose for mechanical oil pressure gauge...how to fix? CaifanSC Technical Forum 4 04-03-2007 12:09 AM
Mechanical oil pressure gauge??? Mark B. White Technical Forum 3 06-25-2003 02:38 PM
OIL Temp. gauge? Ryan A Harris Super Coupe Club of Ontario 6 08-23-2002 07:10 PM
Powered by vBulletin® Version 3.8.7
Copyright ©2000 - 2013, vBulletin Solutions, Inc.
Copyright ©1996 - 2012, Super Coupe Club of America, Inc.
