Super Coupe Club of America Forums
Go Back   Super Coupe Club of America Forums > General SCCoA Forums > Technical Forum
User Name
Password
Register FAQ Garage Chat Search Today's Posts Mark Forums Read
Reply
Thread Tools Rate Thread Display Modes
  #1
Old 06-01-2012, 02:34 PM
rapper33142 rapper33142 is offline
newbie of the year
SCCoA Member #: 3765
Send a message via AIM to rapper33142 Send a message via Yahoo to rapper33142
blown oil pressure sensor
I was on the highway driving home then a mustang gt started messing with me so I had to show him his gt is slow .. I dont know how fast I was going cuz my speed ometer was maxed out .. I got home and I noticed I had a puddle of oil under my car . started looking from where it was coming from and then I seen the blown oil pressure sensor . I do have a high volume oil pump .. has this happen to anybody ?
  #2
Old 06-01-2012, 03:05 PM
nickleman60's Avatar
nickleman60 nickleman60 is online now
Soon to be a 10 sec SC
SCCoA Member #: 2406
Sensor failed, just buy another one. It has nothing to do with the high volume oil pump.
__________________
'94 SC AUTO - Twisted Blackbird
  #3
Old 06-01-2012, 03:27 PM
DrFishbone's Avatar
DrFishbone DrFishbone is offline
SC Surgeon
SCCoA Member #: 2325
Yes, it has happened to me and a few others that I know of. Seems like the fail without much warning too. My oil pickup had started sucking in air before I realized there was a problem!!
__________________
2009 SS Champ ¦ 2010 Mod1 1st Runner-up ¦ 2011 Bracket 2nd Runner-up ¦ 2012 Bracket Champ
Black '89 5spd - 266K miles ¦ RWHP: 301 RWTQ: 375 ¦ Best 1/4mi:13.011, MPH:107.18mph
Red '93 Auto
2003 Mustang GT Convertible
White '89 5spd
  #4
Old 06-01-2012, 03:31 PM
RalphP RalphP is offline
Old Fogie
SCCoA Member #: 3788
While you're replacing the sensor, take a gander at this thread and consider upgrading to an oil pressure gauge that IS an oil pressure gauge instead of an idjit light ... http://forums.tccoa.com/showthread.php?t=75977
  #5
Old 06-01-2012, 10:11 PM
newbie of the year
ok cool thanks guys !!!!!!!
  #6
Old 09-07-2012, 11:19 AM
TBirdSC89 TBirdSC89 is offline
SC Newbie
oil sensor failed?
little old thread but mine just did this yesterday, except my leak seems to be coming from the front timing cover too. would a bad sensor cause it to leak from anywhere? I've never had this happen before it's weird
  #7
Old 09-07-2012, 11:57 AM
David Neibert's Avatar
David Neibert David Neibert is online now
Still loves the Cobra Rs
SCCoA Member #: 858
Quote:
The sensor itself will sometimes spring a leak because of a mechanical failure, it doesn't cause other areas on the motor to start leaking oil. BTW, the oil pressure sensor/sender is located on the drivers side of the motor face, right next to the timing cover.
__________________
91 SC AOD 4.2..2.3 Whipple........10.92 @ 126.70
93 SC AOD 347 Turbo.................10.04 @ 138.99
  #8
Old 09-07-2012, 12:21 PM
SC Newbie
Well that means I got other problems cause I lost all oil and have zero oil pressure too. I mean it seems to be coming from the front cover, and i got everything torn to the sensor. I'd say the sensor was spraying oil but oil is leaking from both sides of the front cover
  #9
Old 09-07-2012, 03:29 PM
Quik95SC's Avatar
Quik95SC Quik95SC is offline
350 HP Club
SCCoA Member #: 2998
Sounds similar to my problem. I had a stuck high oil pressure bypass valve inside the front cover which let the oil pressure get to high and blew out 2 oil filter seals do to high pressure. I had good oil pressure then no oil pressure, look under the car and all my oil is running down the driveway!!
You may be doing the same thing except coming from the timing cover instead. Not sure if you can get the high pressure valve thingy seperate, but a new one comes with the new oil pump. I had to lightly "hone out" the passage the high pressure valve goes in cause it was filled with gunt and stuck on deposits, but very lightly on the honing, Super fine emory cloth on a round bristle brush attached to my drill did the trick
Smitty
__________________
White 1994 Auto SC......................No ET
Venetian Blue 1995 5 Spd...............No ET
Orange Crush Pearl 1995 Auto SC........12.158 @ 108 MPH
355 RWHP 391 RWTQ
2011 SC Shootout MOD 2 Winner & Track Champion!
2012 SC Shootout MOD 3 Winner
Garage:http://www.sccoa.com/forums/garage_v..._vehicle&id=13
  #10
Old 09-07-2012, 03:35 PM
Quik95SC's Avatar
350 HP Club
Clean it all off very good.
Add new oil and a cheap filter, then have friend start it while you are under the car, to see if it is coming from the oil filter gasket area. Shut off immediately if you see it start to stream or flow out, you have no oil pressure if it is!!
That where mine was leaking from, but as it had oil every where it was hard to see where it was coming from exactly until I did that, but I have remote start on my SC so I could do it myself.
Hope this helps you out.
Smitty
__________________
355 RWHP 391 RWTQ
  #11
Old 09-07-2012, 04:16 PM
SC Newbie
Appreciate the help smitty thank you I did do the oil change and its definitely coming out the cover. It shocked me cause when I came out of Fred Meyer I thought i parked in a space where someone dumped out a soda but I'm glad I bent down and checked cause I would of blown my motor driving it home. That's cool that you have remote start is that hard to set up on these sc's?
Reply
Thread Tools
Display Modes Rate This Thread
Rate This Thread:
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Forum Jump
Thread Thread Starter Forum Replies Last Post
Oil Pressure Lost Mikko Technical Forum 2 08-08-2011 09:31 PM
Oil Pressure Help!!!!!!!! deano_90sc Technical Forum 13 01-20-2006 04:44 PM
Replaced Alternator, but now my Oil Pressure guage says theres no pressure syphon Technical Forum 19 12-04-2004 05:12 PM
Maintenance Schedule? Flip New SC Owner Forum 2 08-31-2003 07:36 PM
Powered by vBulletin® Version 3.8.7
Copyright ©2000 - 2013, vBulletin Solutions, Inc.
Copyright ©1996 - 2012, Super Coupe Club of America, Inc.
