Super Coupe Club of America Forums
Go Back   Super Coupe Club of America Forums > General SCCoA Forums > Technical Forum
User Name
Password
Register FAQ Garage Chat Search Today's Posts Mark Forums Read
Reply
Thread Tools Rate Thread Display Modes
  #1
Old 06-08-2012, 10:45 AM
schwalbe schwalbe is offline
Rear main?
The rearmain, how do you replace it? Does the crank have to be dropped?
  #2
Old 06-08-2012, 11:05 AM
nmcbchief's Avatar
nmcbchief nmcbchief is offline
Shade Tree Powder Coating
SCCoA Member #: 3745
Rear main bearing? Yes remove crank.
__________________
US Navy Veteran Retired
"I've done so much with so little for so long that now I can do anything with nothing."
http://www.sccoa.com/forums/garage.p..._view&id=28414
  #3
Old 06-08-2012, 11:23 AM
90sc35thann's Avatar
90sc35thann 90sc35thann is offline
Needs more cowbell
If you are referring to the rear main seal then the simplest way is to remove the transmission and then either remove your flexplate or flywheel and pop out the old seal and insert the new one. it's easy to repair once the transmission is out of the car. It totally sucks too, because you end up working many hours for a cheap $20 seal that take all of about 2 minutes to change once the transmission is out.
  #4
Old 06-08-2012, 11:32 AM
That's what I figured. I just wanted to make sure the seal was that easy. Thanks for the info.
  #5
Old 06-08-2012, 11:56 AM
DrFishbone's Avatar
DrFishbone DrFishbone is offline
SC Surgeon
SCCoA Member #: 2325
Quote:
Alot of times the rear main seals on these cars actually wears a groove into the crank. If this is the case, even after you replace the seal, it will still leak. Felpro has a sleeve kit to help...
However...I installed the sleeve and new seal when re-installing my engine, but I still ended up with a leak back there. Maybe I just did something dumb that I haven't realized yet...
__________________
2009 SS Champ ¦ 2010 Mod1 1st Runner-up ¦ 2011 Bracket 2nd Runner-up ¦ 2012 Bracket Champ
Black '89 5spd - 266K miles ¦ RWHP: 301 RWTQ: 375 ¦ Best 1/4mi:13.011, MPH:107.18mph
Red '93 Auto
2003 Mustang GT Convertible
White '89 5spd
  #6
Old 06-08-2012, 12:30 PM
It's only got like 105k on it so I am hoping for the best
  #7
Old 06-08-2012, 12:46 PM
Needs more cowbell
You can only use the sleeve with a neoprene style rear main seal. The ptfe seal recommends against using a sleeve and be advised you are not to use any grease on the ptfe seal as it wil leak.
  #8
Old 06-08-2012, 12:50 PM
DrFishbone's Avatar
SC Surgeon
Quote:
Right. I think the Felpro box had this info on it too.
You also have to buy a special tool to install it...
__________________
Red '93 Auto
White '89 5spd
  #9
Old 06-08-2012, 12:55 PM
Needs more cowbell
typically the ptfe seals come with a dispoable plastic installation tool. It's nothing more than a plastic sleeve you remove once the seal is installed. I have had good luck with the ptfe seals. My crankshaft also had a groove in it as well. I just rebuilt my engine and saw this. It is very agravating as I am still trying to wrap my head around how a cheesy rubber seal can wear a forged steel crankshaft. LOL I am firing the motor up this weekend for the first time so I hope I don't have the dreaded drip, drip, drip. LOL Then again most forced induction engines develop leaks over time as they build up a significant more amount of crankcase pressure as the engine ages.
  #10
Old 06-08-2012, 01:00 PM
All they had is the rubber seal so I just got that hopefully it will work
  #11
Old 06-08-2012, 06:54 PM
RalphP RalphP is offline
Old Fogie
SCCoA Member #: 3788
... I am still trying to wrap my head around how a cheesy rubber seal can wear a forged steel crankshaft.
Before I replaced the harmonic balancer on my 2000 Malibu (at almost 300Kmiles on it!), I was leaking a quart every 1200 miles. Swapped the balancer (which was grooved), and now I'm at > 3,000 miles per quart.
I'm still trying to figure that out also.
(Actually had to add at 4,200 miles - been running, haven't changed it yet. Can't be TOO bad, car has 323Kmiles on the original motor and tranny ... )
  #12
Old 06-10-2012, 06:10 PM
Mike Puckett's Avatar
Mike Puckett Mike Puckett is offline
SC Newbie
SCCoA Member #: 272
The rear main on my new built motor leaks slightly, too, so I don't feel so bad now. I couldn't get the teflon seal to fit with the mains torqued so I used the neoprene. I should have put it in before I torqued the mains for the last time. I think I'll clip a sponge to it and change it every month. I'll redo it next time I pull the tranny.
My old balancer leaked oil, too. It runs down the crank snout, thru the press fit and out from under the washer.
__________________
90 5spd, best E.T. 12.250
best 1/4mi speed 112.89 mph
best dyno 388.42 rwhp 419.68 rwt
2004 Cadillac CTS, 14.616 @ 91.84mph.
  #13
Old 06-11-2012, 08:47 AM
mywhite89's Avatar
mywhite89 mywhite89 is offline
Chris Homan
SCCoA Member #: 3143
Send a message via Yahoo to mywhite89
Including the original rebuild, I have replaced the rear main seal 3 times on my 89, and it still leaks. I don't see a groove but I need to do the speedy sleeve repair to it. The 95 had a rear main leak and a visible groove on the crank. Did the speedy sleeve and it worked great. Comes with a round enclose cup that you smack it on with. You have to pull the rear main cap off to do it though. I may pull the engine out on my car this year and freshen some things like that up so I don't have any leaks(HOPEFULLY). That and the thermostat housing coolant leak I cannot successfully fix on the 89. I need a hero.
chris
__________________
89 SC 5-speed 1.7 Autorotor twin screw over 425rwhp
95 SC auto mpx powered M90 310rwhp
92 SC Auto stock(just bought)
my email
  #14
Old 06-11-2012, 08:55 AM
BirdofPrey97's Avatar
BirdofPrey97 BirdofPrey97 is offline
Race the other guy
SCCoA Member #: 3187
Sheet rock screw is what I use to get them out. Just drill it up in there until it bites (by hand) and pull the old seal out. Check the crank with a mirror all the way around and install the new seal with a slight coating of oil or tranny fluid on it.
__________________
Honor, Grace and Dignity......Remember these
  #15
Old 07-08-2012, 03:06 AM
1qwik99's Avatar
1qwik99 1qwik99 is offline
SCCOA Member
Rear Main seal
I am in the process of buying a 95'SC A.T, blue mist metallic, with 56K miles on it. The seller told me, and sent pictures indicating that there is possibly a rear main seal leak. The car has been sitting in a garage on a trickle charger and started once or twice a month for the past 8-10 years. The rest of the car looks extremely good for its age. My questions are:
1. How much should it cost to repair at a shop / dealership
2. Has anyone here used AT-205 stop leak as shown on Youtube? have they been successful? Amazon.com sells it and it got 56 ratings, most of them were 4-5 stars.
Thanks for your input. Rick.... a newbe to SC's.
Reply
Thread Tools
Display Modes Rate This Thread
Rate This Thread:
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Forum Jump
Thread Thread Starter Forum Replies Last Post
Replacing The Rear Main Seal*have teflon pt. number mywhite89 Technical Forum 19 12-05-2007 04:12 PM
An SC or Mark VIII rear end????!!!!???? Mercury267 Technical Forum 10 03-28-2005 03:12 PM
Rear main seal Ryan A Harris Super Coupe Club of Ontario 5 09-19-2003 01:44 PM
Quick rear main seal ??? PIC Bigme574 Technical Forum 7 08-01-2003 07:16 PM
Rear Main Seal Install? wezar Technical Forum 6 06-08-2003 01:55 AM
Powered by vBulletin® Version 3.8.7
Copyright ©2000 - 2013, vBulletin Solutions, Inc.
Copyright ©1996 - 2012, Super Coupe Club of America, Inc.
