DrFishbone
SCCoA Member
Anyone that has installed the stainless steel brake line kit (particularly on 89-92 cars), I've got a question for you...
At the driver's rear wheel well, the block that is attached to the factory flexible hose has two threaded ports: one from the ABS assembly and one that goes over to the passenger wheel well. What did you do to replace that block - or essentially "tee"? Whatever details (PN's or thread sizes) you have would be appreciated too. Also, if you had the 89-92 kit, were all four car-side connections the same?
Seem like I may need to buy and tee and/or adapter in addition to what I received in the kit.
Thanks!!
Thanks!!
