#16
Can you hook the starter to the cars wiring and have someone else turn the key to see if the bendix moves? Is it making a grinding noise when you try to start?
__________________
~Chris SCCoA Member #1826 Riding jack stands. |
#17
Quote:
That is how I tested it last night. It doesn't make any grinding noise. The starter just spins, like it is free. The bendix moved perfectly fine. I am thinking about placing clay against the flywheel to see where it is hitting. Thanks Ken
__________________
1992 Thunderbird SC 13.322 @ 102.81 1993 Thunderbird SC 5spd..white 2002 F350 SD Diesel (SC tow vehicle) |
#18
Are you using the original flywheel and crank....
__________________
Flying is the 2nd greatest thrill known to man. Landing is the first !!!! Every day, I set a personal record for consecutive days I have remained alive! If you cut a crumb in half, you don't get two half crumbs, you get two crumbs Doesn't this violate some law of physics? |
#19
Eddie,
Yes, I am using a stock short block. Ken
__________________
#21
David,
The crankshaft is good. I check the bottom of the engine prior to installing it. I can turn the crank. Ken
__________________
#22
It sounds like the starter ring on the flywheel might not be in the correct position....
I like using the clay idea.... ![]()
__________________
#23
I tried the clay trick..it engaged for a sec then spins. I changed the battery, solenoid and the same thing. I am completely stumped. When I start the car the volts go from 12.0 to 9.8...does that sound right?
Thanks ken
__________________
#24
A little low. You should have about 12.5 no load on the batt and depending on the cranking amp rating is usually in the 10's somewhere when starting.
__________________
#25
It sounds to me like the bendix (the part that moves the pinion out to contact the flywheel) on the strarter is bad. Try installing a new starter
__________________
#26
You won't believe this.........the motor was spinning. I could not see it from the car. Last night I had a friend come over to look at it and it was turning. I have no compression, that is due to the stud mounted rocker arms being too tight and the valves are open all the time.
Now I have to redo the rocker arms. I hate stud mount rocker arms. I don't have this much trouble with my bolt down rockers. I should have the car done by Monday. Thanks for everyone's help. Ken
__________________
| Thread Tools | |
| Starter issues all over again. Fixed | ricardoa1 | Technical Forum | 79 | 05-03-2012 10:46 AM |
| Starter relay tech question... | Kit Sullivan | Technical Forum | 10 | 08-20-2007 06:39 AM |
| Starter problem! | Rob91 | Technical Forum | 5 | 02-24-2004 01:59 AM |
| Boat starter clicking...questions ? | TBirdDriver | Non Technical Forum | 15 | 07-15-2003 05:01 AM |
| Need help ASAP...... Problem with starter...... | EdmontonSuperCoupe | Super Coupe Club of Western Canada | 8 | 05-20-2002 01:38 PM |
