#1
cruise control mystery
does anybody know where the cruise module is located on the early SC s ? The later cars had it on the brake pedal bracketry and is easy to find!
#2
What kind of CC problem are you having.....
__________________
Flying is the 2nd greatest thrill known to man. Landing is the first !!!! Every day, I set a personal record for consecutive days I have remained alive! If you cut a crumb in half, you don't get two half crumbs, you get two crumbs Doesn't this violate some law of physics? |
#3
it dont work at all and have swaped everything but the control module and thats because i cant find it!
#4
Before you replace anything, make sure the vacuum dump switch on the brake pedal is adjusted correctly!
That being said ... The solenoid is in the driver's fender, behind the splash guard.
__________________
God bless!!! 1990 SC auto ... red outside, gray cloth inside ... ~180,000 miles (and climbing) ... driven daily! |
#5
yup did all that still cant find the module ta swap it!
#6
I don't know what you mean ... what module are you looking for? The mechanical actuator is in the fender. The control is (I believe) handled through the EEC. You want to swap the entire engine computer?
__________________
#7
What year is your car. I think my 94 was under the passenger dash
__________________
http://www.tbirdsc-registry.com 93LX, 96LX, 97LX/LE 95SC/5-Speed, 95SC/5-Speed (Identical) |
| Thread Tools | |
| How to add cruise control illumination to 94/95 SCs | XR7-4.6 | Non Technical Forum | 3 | 04-09-2011 04:21 PM |
| Cruise Control Challenge | cbkid | Technical Forum | 7 | 11-22-2004 12:05 PM |
| Cruise Control & Magnum Powers 85mm Throttle Body | blkthndr | Technical Forum | 1 | 05-07-2003 01:36 PM |
| Cruise control problem Intermittent | Mike Combs | Technical Forum | 10 | 04-13-2003 11:08 AM |
