Best way to add Purple Ice
Been trying to add this stuff to my coolant but cannot simply pour it in the radiator as it is full. I guess I could pour it in the overflow, but I doubt it'll fully work it's way into the cooling system that way. I tried to suck some coolant out of the rad with a coolant tester but the coolant flowed back in from the block and replaced the coolant I had removed. How about I remove the screw on the tube welded to the thermostat housing and pour it into the block from there? Perhaps another option may be to crimp the upper hose when removing coolant from the rad, but I don't wanna break any cords.
Or, I may have to bite the messy bullet and let out about a 1/2 gal from the draincock. Crap, I already have three engines worth of old antifreeze from past builds. BTW, what is the best way to legally dispose/recycle that stuff?
__________________
It's only impossible until we do it. 17-year SC owner - '93 SC AOD (non-locking TC) Current setup: 12.550 @ 111.09, 1.917 60ft, No nitrous. Last edited by pablon2; 06-19-2008 at 10:37 PM.. |
For a minute I thought I read illegally and a million fun and interesting ways came to mind. Legally... I think parts stores are required to take a specific amount back each year for recycling. Anything over that and you pay a premium.
Didn't come back from the block (unless you removed the thermostat), it came from the upper radiator hose tube.
crack the valve at the bottom of the radiator and dump it into a container. Then fill the radiator up with the purple ice, and top off the radiator with what you took out. Have the front end jacked up while you do this to keep the radiator as the highest point, higher than the upper tube. hmm, sorry for the technical answer in the non tech forum. ![]()
__________________
90 SC AOD 93 SC 5spd -441hp/462tq *SOLD* |
Auto site
Read on some site, when i was looking for disposal methods, that it was ok to pour down toilet, just not in storm drains or ground, apparently flushing it is an acceptable method of disposal. wont go directly into ground water supply...just a thought....im not going to say i did it.
#5
Quote:
__________________
It's only impossible until we do it. 17-year SC owner - '93 SC AOD (non-locking TC) Current setup: 12.550 @ 111.09, 1.917 60ft, No nitrous. |
#6
Quote:
__________________
#7
Some cities/towns have household chemical recycling days. I used to work them when I worked in HazMat. You just gather all your old bad stuff and bring it to them and they recycle what they can and properly dispose of the rest. It's usually free and you won't have the hills have eyes people walking around in a few years. Not as much anyways.
#8
Quote:
__________________
#9
Quote:
#10
Won't be able to throw it in until 10:00pm if I have to wait until dark. ![]()
__________________
#11
Hazardous Waste
Automotive fluids include items such as: * Antifreeze * Break fluid * Coolant * Gasoline * Motor oil * Power steering fluid * Transmission fluid Bring automotive fluids to the Sherburne County Mobile Household Hazardous Waste Collection Events. It is illegal to place most automotive fluids in the garbage. Do not pour automotive fluids down the drain, on the ground or down a storm drain. Some service stations accept automotive fluids for a fee. Call first. For larger quantities of oil, see oil & filter disposal information. Four or more gallons of gasoline may be brought to: East Side Oil 625 SE Lincoln Ave. St. Cloud, MN 56304 (320) 252-9711 http://www.co.sherburne.mn.us/zoning/environ/auto.htm
__________________
#12
Quote:
Good info Mike....I wonder if I have to live in Sherburne cty.
__________________
#13
Probably not. The ones I worked were kind of an advertising event for the hazmat co. I worked for. They're usually a notch in some city politicians belt too. The only disadvantage is waiting in your car in a line of tree huggers dropping off their AA batteries and flourescent light bulbs. We accepted any quantity as long as it was household and didn't look like it came from an auto garage or other commercial site.
#14
Quote:
I passed off 25 oil filters to my mom who dropped them off at her county's recycling event.
__________________
#15
Where is all that oil coming from? Not to mention all those filters..... I didn't know Minnesota had more oil than Texas.
| Thread Tools | |
| Another [expletive] Ice Storm?!!? | 351cat | Super Coupe Club of the Midwest | 9 | 02-22-2008 10:11 PM |
| Mobil 1 VS. Royal Purple | Thunder427 | Technical Forum | 4 | 12-04-2005 01:57 AM |
| Drifting experience pays off when driving on ice | 1QuikV6 | Non Technical Forum | 7 | 12-24-2004 06:53 PM |
| I may be psychotic......Dry Ice & CAI | Dahoopd | Technical Forum | 18 | 07-14-2004 12:13 PM |
