ARP head stud part numbers
I did a search and came up with two numbers
143-4003 143-4303 Both are listed for a GM V-6 at Summit Which ones are the ones to use on my 91? thanks Ron |
You need the 2.8 V6 Chevy studs,
233-4003 are 6 point nuts 233-4303 are 12 point nuts The 6 point version is almost $30 cheaper, about $85. |
yeah I saw that one was less money, as long as they both work then the six points will be the ones
thanks Ron |
Don't forget to order some ARP Assembly Lube, and ARP Teflon Thread Sealer also as they are not included with the stud kit.
| Thread Tools | |
| I found this FAQ on the SC | Active non member | Super Coupe Club of Western Canada | 14 | 11-06-2010 11:31 PM |
| head gasket part numbers | papayomomma | Technical Forum | 4 | 02-22-2006 10:17 PM |
| ARP Head studs and Fel Pro head gaskets | V698Pony | Parts for Sale | 3 | 11-21-2005 02:12 PM |
| DIS Module Part Numbers | gldiii | FAQ Forum | 0 | 02-21-2003 04:33 PM |
| arp head stud torque specs and sequence | blownsc | Technical Forum | 3 | 06-25-2002 03:31 AM |
