Thread Tools | Rate Thread | Display Modes |
Wiseco OE replacement FORGED pistons...*UPDATED 2/20/09* (CLOSED)
Edit: Release date is March 13th. Now taking orders!
As many of you know I've been working with Wiseco to bring you custom forged pistons for your SC motors for some time now. By building this relationship and showing a proven track record of selling these pistons (over 50 sets in 2 years), we have been able to get the attention of the higher ups at Wiseco. Because of this overwhelming support of this club in purchasing Wiseco pistons through me, I have been able to negotiate a new deal with Wiseco to where they have agreed to build an off-the-shelf forged piston for us! Yes, that will be a forged piston in their "Pro Tru" line that will be a direct replacement for the stock pistons which can also be fit to a CAT 5.915" H-beam rod. These pistons will be direct drop in replacements for all 89-95 SC's giving 8.5:1 compression, machined to accept either full floating or press fit applications depending on year, and will NOT require rebalancing of the motor. With custom piston packages running upwards to $750 these days and a proper engine balance starting at $200 and up, these pistons can result in a savings of over $500 (!) Wiseco will have shelf stock available in about 4 weeks which you can order direct from them for $510 + shipping. This includes the pistons, rings, and pins. From Supercoupes Unlimited these piston sets (pistons, rings, pins) will cost $475 shipped (lower 48) which when compared to the old hyperutectic pistons (and rings) from Sealed Power ($330 at Rock Auto when you can get them), is actually about the bargain of the century for SC owners. They will be available in .020" and .030" with no waiting (once they hit the shelves). Part #'s: PT-113-H2 (.020") PT-113-H3 (.030") There you go, proof that at least some parts manufactures will listen when we speak. Also one more reason why it also pays to channel some of your buying power through someone who is working on your behalf instead of sourcing parts individually through local channels. By working together to present one voice, we can actually accomplish good things from time to time. ![]()
__________________
Email me here. Last edited by XR7 Dave; 07-19-2009 at 08:17 AM.. |
I think a big thanks goes out to SCU, for all the hard work in getting a new product developed and released.
What kind of ring packages will be available for these pistons? |
Great Job. So it will they need special machining if they are being used with the CAT rods or will it interchange.
__________________
1994 Supercoupe 5spd Custom Modded. 2010 Shootout-Best Custom Award-415WHP off the bottle-12.2535 @112.18 off the bottle. Best HP to date 445whp Best TQ to date 516ft/lbs Modified with the 1% $$ 1990 35th 5spd 2011 Carlisle 1st place class winner. 12.9@108MPH 1.9/60fts Modified with the 99% $$ 2 SCs 12sec club member. |
Thank you Dave! We as a community are lucky to have you!
![]() ![]() ![]() Stephen |
#5
Quote:
Quote:
__________________
Email me here. |
#6
Dave,
Another thanks for what you do and have done for this community. Any reason these wont work with the scat 5.956 H-Beam rods? |
#7
Are these stock compression only I forget what itis can you get them in 10:1 CR? How much are the 5.915" Cat rods going for? Bonus check in a few weeks time to get some goodies
#8
The compression distance is set for stock length rods. If you already have the 351W rods and wanted to use these pistons I can cut them down .040" but that would cost extra. If you have not already bought the rods then it would only make sense to get the correct rods.
Quote:
Quote:
__________________
Email me here. |
#9
Great news.
#10
What is the mass of the pistons and the pins?
__________________
CORN GAAAAASSS!!!
#11
I have another set of brand new 5.956's. Forgive me, but I don't know what a "Cat" rod is. Is this a stock type, I beam, or H-beam?? Cost of milling the pistons .040" is about how much?? The reason for wanting these and not the custom, is the fact that the block I'm using is low mileage and I would prefer std bore if possible.
#12
Quote:
Quote:
Cost to trim the piston decks is $75. Custom pistons are available in any bore size you want including std. There is a significant cost difference but there are advantages also such as being able to select your compression ratio and lighter weight.
__________________
Email me here. |
#13
from a comparative standpoint, is a majority of the assymbly weight at the big end of rod or at the piston?
What are the piston weights in comparison to stock?
__________________
#14
Quote:
As for the CAT rods, the stock rod big end is heavier than the H-beams so if you run the H-beams you really need to rebalance the motor.
__________________
Email me here. |
#15
Quote:
Good to know there is a good forged piston replacement for us out there
__________________
1994 5 speed-Who needs a MAF anyways! 0 RWHP--0RWT 0 @ 0mph http://www.sccoa.com/forums/garage_v...vehicle&id=110 Last edited by XxSlowpokexX; 11-16-2008 at 02:55 AM.. |
| Thread Tools | |
| Wiseco Pistons group buy opportunity | XR7 Dave | Group Purchases / Specials | 45 | 05-02-2008 08:34 PM |
| Looking for forged pistons | Flex | Want to Buy | 0 | 10-12-2007 08:48 PM |
| BRC Custom Forged Blower Pistons. | 22lbsofboost | Group Purchases / Specials | 3 | 06-24-2006 10:15 AM |
| I need oversized forged SC pistons | lilredstang | Non Technical Forum | 2 | 08-19-2005 05:01 PM |
| How much nitrous before forged pistons... | sizemoremk | Technical Forum | 24 | 03-16-2005 12:03 PM |
