| View Poll Results: How should I overdrive my MPII blower??? | |||
| 10% OD supercharger pulley + stock jackshaft |
4 | 26.67% |
| 7-10% OD supercharger pulley + stock jackshaft |
1 | 6.67% |
| 94/95 SC pulley + 10% jackshaft |
7 | 46.67% |
| 94/95 SC pulley + 5% jackshaft |
3 | 20.00% |
| Voters: 15. You may not vote on this poll | |||
Thread Tools | Rate Thread | Display Modes |
How should I OD my MPII?
I have a couple options here and I want opinions on the best way to OD the SC. It already has the 10% sc pulley, but I know it's a better option to run the jackshaft OD pulley to keep belt slip at a minimum. Engine is stock with 86k miles. It's a junkyard 95 motor with new bearings and seals.
I have the MP springs, catless exhaust, K&N intake mod, underdrives, stock 36's for now with stock 94/95 plenum, MP FMIC. Any info is appreciated. Car will obviously need injectors and the inlet plenum. That's next on the list. Last edited by tydlwavs; 01-14-2009 at 04:17 PM.. |
Depends on how much od you want. For 10% od I say the best with the least slip is a 10% crank pulley.
__________________
SCCOA Member #2406 '94 SC AUTO - Twisted Blackbird http://www.sccoa.com/forums/garage_v..._vehicle&id=19 |
I have underdrives.
Pitch the underdrives and run the OD Crank and Jackshaft with a stock supercharger pulley. I didnt see much help at all from the underdrives and with trying to keep belt slip at a minimum you want to have as much contact as possible on the SC pulley. Just my two cents.
__________________
Anthony Arnold Home of "No Cash Racing!" Silver 90 AOD 12.03 Shootout 2010 Black 92 AOD 12.77@109.5 10/12/07 |
#5
Personally, 5% SC and 5% jackshaft.
Fraser |
#6
That's what I did. On the dyno, I was starting to have a bit of belt slip towards the end, but I think if I had the MP springs - I wouldn't have had the slip.
-Melon |
#7
Run 15%, 5 on the SC and 10 on the JS, and keep the UD's. I ran the MP 10 rib 15% kit on mine and made 265rwhp on a stock block.
#8
I'd like to stick with 5-10% OD on the blower.
-Todd |
#9
Overdriving with the crank pully and jackshaft is best, because it increases the surface area for the supercharger belts to grip.
__________________
#10
I was told that the 10% SCI jackshaft overdrives the crank 5% and the blower 5%. Is that true? Just want to verify this.
#11
Quote:
The overdrive on my ESM 10% jackshaft pulley is all on the supercharger belt side (it's 10% larger OD). The portion that is driven from the crankshaft pulley is the same diameter as stock and still uses a stock belt. Don't know anything about how SCI does it. David
__________________
#12
I can't get to the search function for some reason. I'll have to ask Ryan. I do have MP springs and I'm lookin pretty hard at the 94/95 pulley and a 10% jackshaft pulley so I am not quite running a full 10% OD. I'll see if my 5% belt fits this set-up.
Just waiting on payment for my 5% and the 10% sc pulley to make my purchase later today. |
#13
I got the same thing goin on. No complaints.
| Thread Tools | |
| Polished MPII Blower and Plenum | XxSlowpokexX | Parts for Sale | 9 | 05-05-2008 10:29 PM |
| MPII, 5% SC pulley, Outlet Plenum w/divider, 89 SC, 89SC pulley.... | BirdofPrey97 | Parts for Sale | 46 | 03-12-2008 05:13 PM |
| S port vs MPII | XxSlowpokexX | Non Technical Forum | 28 | 10-11-2007 09:26 PM |
| MPII supercharger and MPII plenum for sale | superbirdx | Parts for Sale | 13 | 09-14-2007 05:03 AM |
| WTB MPII blower MPII intake 85mm TB | Flint | Want to Buy | 2 | 01-19-2006 06:44 PM |
