#46
351w can be had for under 500 and you save money by not having to build the bottom, but its ok, you can still build a killer 363.
#47
Quote:
http://forums.tccoa.com/showthread.php?t=118810 David
__________________
#48
Quote:
Does anyone have the 5.0 TBird kit from Kenne-Bell? |
#49
Quote:
__________________
Email me here. |
#50
I currently own 3 supercoupes (3x v6 3.8 supercharged) and a 92 stock 5.0 lx that i swapped in a 351w and m5r2.
If i had it my way I would have stayed with the 5.0 and put a supercharger on it like I originally wanted to. Only reason why I went with the 351w is because I threw 2 rods in the 5.0. Thats when the 351w swap for a few hundred more appealed to me. Anyway, just thought I'd share. If your interested in knowing how involved it is I have a swap thread. http://forums.tccoa.com/showthread.php?t=103398&page=19 |
#51
Quote:
One of my goals is to eliminate the M5R2 in favor of something like a T56. I find M5R2s to very difficult to shift quickly, particularly in lower gears. |
#52
The problem with the M5R2 being difficult to shift is entirely in the shifter. Replace the stock ~~~ shifter with a B&M ripper, and it shifts just fine. Plus the M5R2 is strong and cheap, whereas the T5 is weak and cheap and the T56 is strong and expensive.
#53
Quote:
I agree the that M5R2 is strong and cheap, and the T56 is expensive, but it does have one extra gear. Also, I had always heard that the M5R2 would not bolt up to a smallblock. Is an adapter required? |
#54
Nope. The 3.8 and the SBF have the exact same bell housing bolt pattern. The only thing is you need to get the correct flywheel, or have the SC flywheel rebalanced. Other than that, its a direct bolt-in swap.
#55
How do the shifter locations compare between M5R2 and 91 mustang T5?
#56
The T5 shifter will come up about 6" too far forward for the tbird. The M5R2 will come out in the exact right location.
| Thread Tools | |
| About to do an engine swap! What shall I look for? | repoman27 | Technical Forum | 3 | 07-03-2006 12:15 AM |
| holy crap. Jet engine VW BUG!!! | SCandelous95 | Non Technical Forum | 3 | 06-27-2006 09:49 PM |
| When is a Coy Miller Race Engine not actually a Race Engine? | RalphSparveri | Non Technical Forum | 130 | 04-28-2006 08:13 AM |
| Cobra engine swap? Some ideas???? | ricardoa1 | Technical Forum | 31 | 10-27-2005 10:50 PM |
| Engine Swap Questions | ThunderCoupe94 | Technical Forum | 1 | 10-15-2005 05:42 PM |
