This Weekend Is It!!!!!
This weekend I'm FINALLY going to put my rebuilt motor, performance goodies, and low miles 5-spd in the ole' black SC. Although it's only been about 2 years since I drove the car, I've been waiting for this for over 4 years!!!! Hopefully my back doesn't start acting up again and further delay this momentous occasion!
![]() I'll finally have a car that I'll be glad to take to the shootout, dragstrip, wherever! Maybe after this weekend I can stop saying "When I get my new engine and trans in my car...." ![]() Anyways...I'm pumped ![]() ![]() ![]() ![]()
__________________
Matt Haub 2009 SS Champ ¦ 2010 Mod1 1st Runner-up ¦ 2011 Bracket 2nd Runner-up ¦ 2012 Bracket Champ Black '89 5spd - 266K miles ¦ RWHP: 301 RWTQ: 375 ¦ Best 1/4mi:13.011, MPH:107.18mph Red '93 Auto 2003 Mustang GT Convertible White '89 5spd My Garage |
Quote:
![]() Ken |
Good luck dude!
__________________
I hope to get the engine and trans in at least most of the way by Monday...hopefully before too much longer, it'll be moving...then I can start pretty-ing it up too.
AND...then I can go ahead and get my QH, etc! I've been putting off on buyin all the tuning/datalogging stuff until I have a fun engine to mess with.I'll take some before pictures of everything to document the work, but I gotta warn you all - it's a pretty dirty boy right now. I'll have to scan my parts list that I've been adding to in the past 4 years too. Once I'm finished, I'll add up the total cost, then throw up. Nah, it shouldn't be too bad...been on the "buy-it-cheap" budget since day one, but haven't been willing to sacrafice quality parts.
__________________
#5
Quote:
Wow! I would get inpatient not putting that in after a month...4 YEARS? You must be pumped. I hope it's all you hoped for and more. What sort of perf. goodies are we talking about for this re-built motor? Good luck dude. |
#6
Yeah...it's been a long wait. I finally knew the time was getting close when I started becoming uninterested in the "Parts For Sale" forum.
![]() It's not going to be one of the Whipple or AR cars by any means - I hope to use it as a semi-daily driver. I've got a Magnuson S-port blower, raised top, MP inlet, 75mm Professional Products TB, 76mm MAFS, homemade aluminum 3" intake tube, double IC (to be upgraded to a custom FMIC at a later date), I did some port work on the intake manifold (porting around the inlet, and gasket-matched and smoothed all runners), home-ported heads with 3-angle valve job, .520 lift reground cam, 94-95 windage tray, 42lb injectors, adjustable FPR, 255lph hi-pressure fuel pump, b&m short-throw, spec II clutch, aluminum flywheel, 3.27 rear gears, aluminum stock-size pullies, 5% OD jackshaft pulley, 5% OD SC pulley, AC delete, ported exhaust manifolds, dual 2.5 exhaust w/ dynomax superturbos, and a NOS sticker. I think that's it...but probably not. The next phase will be the suspension / brakes, but I can do that piece-by piece if needed. Someday I may think about an MP3 or MPX...but hopefully I'll be happy with the change for a few years ![]()
__________________
#7
Hey Matt,
Good luck with the install man...I'm actually going to be out of town this weekend or I would stop by to lend a hand, can still do so next weekend if you need a hand on finishing up whatever, would be happy too! I'll give you a call later.... Jeff
__________________
boostinmy89@eastsidethunderbirds.com '1691' off the line in 89 Born: Feb. 08,1989 Powered By: Magnum Powers MPIII - w/CUSTOM FMIC260 RWHP / 346 RWTQ @15.9 lbs Of Boost
#8
Quote:
![]() I'm hoping to get the big work done this weekend, but we'll see! Finally...I won't have an excuse huh?! ![]()
__________________
#9
Sounds like a good solid combo, that should be great on the street and run some good numbers at the track too. Take your time and do a good job of sealing everything up and zip tie or clamp all of the vacuum hose connections. Leak test your fuel system before installing the supercharger.
__________________
#10
Quote:
Maybe in the next few days I'll at least have the new motor and trans sitting in the car.David, I read a thread awhile back about pulling the motor and trans together, rather than separate - is that how you'd done it before? I was thinking that you recommended doing it that way. Anyhow, that's was I ended up doing. I thought I might be able to leave the custom exhaust and driveshaft bolted up (except the obvious), but that didn't work out, I had to unbolt the driveshaft to get the motor/trans up high enough to pull it forward. It did work quite well, and saved alot of under-the-car work, which is less fun! ![]()
__________________
Matt Haub 2009 SS Champ ¦ 2010 Mod1 1st Runner-up ¦ 2011 Bracket 2nd Runner-up ¦ 2012 Bracket Champ Black '89 5spd - 266K miles ¦ RWHP: 301 RWTQ: 375 ¦ Best 1/4mi:13.011, MPH:107.18mph Red '93 Auto 2003 Mustang GT Convertible White '89 5spd My Garage Last edited by DrFishbone; 05-26-2009 at 11:37 AM.. |
#11
Quote:
__________________
#12
Quote:
__________________
'94 SC AUTO - Twisted Blackbird http://www.sccoa.com/forums/garage_v..._vehicle&id=19 |
#13
j/k
No juice, maybe meth injection in the future..who knows.
__________________
#14
Now I knwo why those poly bushings lasted so long..ITS BEEN ON JACKSTANDS! hehehe
__________________
#15
Quote:
The car hasn't been PARKED for four years though...I've just been accumulated parts for four years. I guess it's been parked for around 2 years. It started right up and ran just fine when I moved it last Friday. Kinda makes me sad to take out the original motor and trans...no telling how long it could have lasted now. Well Damon, I guess those diff bushings will get a good testing now...maybe then I'll say "Damon was right - these are junk!" ![]()
__________________
| Thread Tools | |
| Well.. weekend at St. Thomas was great for me | drummerzrok24 | Super Coupe Club of Ontario | 8 | 09-20-2006 11:09 PM |
| NMRA TV - Video of NMRA Route 66 All Weekend | nmrajames | Racing/Track Results | 0 | 07-27-2006 12:38 AM |
| Nice weekend back home | mcate | Hampton Roads Super Coupe Club | 6 | 06-28-2006 08:07 PM |
| Weekend at Sebring | Flip | Racing/Track Results | 3 | 04-28-2005 12:34 PM |
| ALL weekend but... | GREATWHITE666 | Non Technical Forum | 8 | 09-09-2003 05:00 PM |
