Go Back   Super Coupe Club of America Forums > General SCCoA Forums > Non Technical Forum
User Name
Password
Reply
Old 10-22-2009, 06:25 PM
Hock's Avatar
Hock Hock is offline
Always Broke
SCCoA Member #: 2574
Send a message via AIM to Hock Send a message via Yahoo to Hock
New FPR location, see pics...
In the constant world of modding my SC I decided to move the fuel pressure regulator to a more accessible location. I'm using the factory base and mount but I mounted it to the heater pipe that goes over the driver side valve cover. I used header wrap and some ducting tape from Lowes to help insulate the heater pipe and keep it from the regulator and make a heat shield from 26 gauge steel as added heat protection. As far as the hose I use Aeroquip -4 socketless hose to connect everything together. Tell me what you all think.
Click image for larger version
ID:	40144   Click image for larger version
ID:	40145   Click image for larger version
ID:	40146   Click image for larger version
ID:	40147   Click image for larger version
__________________
Later,
Hock
92 SC 298rwhp/371rwtq
Uses SC specific head studs from SCP with no problems!
Quote:
Originally Posted by XR7 Dave View Post
If you think low 12's or high 11's is mediocre than you are living in another reality.
Old 10-22-2009, 06:28 PM
Hock's Avatar
Always Broke
more pics...
ID:	40149   Click image for larger version
ID:	40150   Click image for larger version
__________________
Later,
Hock
Old 10-22-2009, 07:52 PM
Mike8675309's Avatar
Mike8675309 Mike8675309 is offline
a little of this and that
SCCoA Member #: 1544
Send a message via AIM to Mike8675309 Send a message via MSN to Mike8675309
I'd be concerned with some of those hoses you are using. Looks like one of them wasn't cut square, and isn't pushed fully onto the steel line. It really should be pushed all the way on.
__________________
90 SC AOD
93 SC 5spd -441hp/462tq *SOLD*
Old 10-22-2009, 08:00 PM
Hock's Avatar
Always Broke
Quote:
The one that you can see clean metal was a bear to get on. Didn't get it all the way the first time so I had to cut the end off and try again but it is over both barbs and impossible to remove.
__________________
Later,
Hock
  #5
Old 10-22-2009, 10:47 PM
DLF's Avatar
DLF DLF is offline
The Delrin Bushings Guy
SCCoA Member #: 1226
It really doesn't look like any of them are all the way on.
The trick to installing that type of hose is lubrication and heat. I use the Aeroquip hose lube and heat the inside end of the hose thoroughly with a heat gun.
__________________
98 Toreador Red Mark VIII LSC - 13.221 @ 104.91
98 Laser Red/Black Cobra Coupe (T-56/IRS) - 12.483 @ 110.94
My Web Site
Delrin IRS Bushing Kits - UHMW Spring Perches - SS Steering Joints
  #6
Old 10-22-2009, 10:54 PM
Hock's Avatar
Always Broke
I figured they are fine since that's as far as the factory hose went. Lubrication was definitely needed unfortunately I don't have heat gun.
Also this is what I used as reference as to how the lines should be: http://www.tccoa.com/articles/mn12ho...fuel-rail.html
__________________
Later,
Hock
  #7
Old 10-23-2009, 08:22 AM
I'm talking about the one that isn't covering the last barb. Note the factory lines are different than the aeroquip stuff, and the barbs on the fuel rails are not exactly spec for the push on hose. That said, it works, but you'll want to make sure all the barbs are fully covered.
The suggest I had for the hose was to run it under some hot water to heat it up. A heat gun will work as well, just need to be careful you don't get it too hot.
__________________
90 SC AOD
  #8
Old 10-23-2009, 12:31 PM
Hock's Avatar
Always Broke
Oh, no, that is covering the last bard. That one was the last one I did and had problems getting it on all the way and had to cut it and redo. I didn't get it cut perfectly straight so it just looks like it didn't go all the way in the pic, but it is I had to really fight with that one to get it there but I got it.
__________________
Later,
Hock
Reply
Thread Tools
Rate This Thread:
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Forum Jump
Stereo Pics thumpjimmy Non Technical Forum 5 11-06-2004 02:22 AM
Finally some pics with the 18" Chromies SC4LIFE Super Coupe Club of Ontario 9 09-27-2004 04:41 PM
How to Add Pics to Member Page ??? SuperCoupe007 Non Technical Forum 2 08-05-2004 11:51 PM
any pics of motor corey796 Technical Forum 3 03-16-2003 12:18 AM
Spliced into FPR vacuum line to feed boost/vac gauge, bad idea? DMX Technical Forum 3 10-30-2002 06:03 PM
