Ok to run w/o an oil filter?
My car doesn't see many miles and I need that space for other components, I have a remote mount now but that's taking up too much space too, any negatives to this?
here's a kind of bypass I want to use |
Seems to me (and I am no master craftsman) that with all of the stories about "I change the filter every 3000 miles and the oil at every 12000" stories that you would realize that with todays synthetic oil that the filter is the most part of the system after the oil pump. I would never run an engine without a filter. As a mater of fact, I never buy a standard filter only the premium ones.
I will go on to say in a Mark 8 any filter that doesnt have a drainback feature causes premature failure of the timing chains and tensioners. |
no filter is basically like playing Roulette with the bearings...
anyone know if race engines have oil filters?
#5
The primary function of the filter is to remove the contaminants from combustion gases in the crankcase combining with the condensation from warming up and cooling that happens with an engine in normal operation. Since the paper in the filter has a greater affinity for the water vapor that condenses than does the oil it absorbs the moisture and holds it so less acid is formed in the crankcase and its the acid that eats up bearings....do away with the filter if you want just change the oil every time you start it and you should be fine---not me for sure though.....................Dan
__________________
I don't think I have ever owned a car that was finished---unless it was totaled.
#6
Quote:
#7
Quote:
David PS: If you need more space delete the oil cooler and remote mount the filter.
__________________
#8
Don't race motors get rebuilt alot?
__________________
35th ANNY Auto UNDER 89000 orig. miles. MAYBE ONE DAY I WILL HAVE MY MP2/MP3 CONVERSION BLOWER AND OTHER PARTS SENT BACK TO ME FROM MANNY. 3246
#9
Quote:
What about using my oil pressure sender hole and running the filter lines through that and drain it back above the oil pan oil line? PS-I like posting over here, the sho's guys don't like PD's S/C's or they don't know as much about them. |
#10
Can't you look at mounting the remote oil filter inside the fender well? It'll be a pain to change, but it'll be out of the way.
Fraser |
#11
Quote:
__________________
#12
Sorry I have 90 degree elbows coming out of the remote adaptor not straight out like the model shows, then the hoses route over inlet tube and the filter is where you can imagine your tow hook point is.
Here an old shot when I was putting in the M90. |
#13
Wow...that makes a Super Coupe look easy to work on. Still can't tell where the oil filter is supposed to be, and I also couldn't help from thinking that it would be a lot easier to use a turbocharger than to try mounting that large of a supercharger down there.
__________________
#14
Quote:
Or just relocate it http://www.sccoa.com/forums/showthread.php?t=73442 Always Smiling, Jerry Last edited by RedSC93; 11-03-2009 at 03:10 PM.. |
#15
Quote:
So what about using the oil pressure switch which is on the backside of the engine? |
| Thread Tools | |
| Does the actual size of the oil filter really matter? | CaifanSC | Technical Forum | 11 | 01-31-2007 01:01 AM |
| oil pressure pegged!!! filter gasket blown!!! | lilredstang | Non Technical Forum | 9 | 08-10-2006 10:25 AM |
| Techincal Review: SC Remote Oil Filter adapter | 68COUGAR | Technical Forum | 22 | 04-01-2006 11:28 AM |
| Question? Oil Filter mount/Oil Cooler | Jeff Bratton | Technical Forum | 2 | 09-12-2005 09:40 AM |
