Go Back   Super Coupe Club of America Forums > General SCCoA Forums > Non Technical Forum
User Name
Password
Reply
Old 01-18-2010, 10:31 PM
Miller Miller is offline
Send a message via AIM to Miller
Wont idle when cold
My 89' 5speed will not idle when its cold. The problem was all of a sudden, it used to run fine.. I had a buddy come over to look at it with me and we played around with it for about 30 minutes and only then would it smooth out and stay idling because it had warmed up..I would think a vac leak but it idles nicely once its running...On cold start, the car starts, and rpms drop down fast and it dies almost immediately .... Any ideas ?
..has new plugs, wires, fuel pump and fuel filter..
Old 01-18-2010, 10:49 PM
BLOWN38's Avatar
BLOWN38 BLOWN38 is offline
HaHa
SCCoA Member #: 1826
Injectors plugged/gummed up? Fuel pressure good? How does it drive once warmed up, will it take throttle or does it feel like its runnin out of fuel?
__________________
~Chris
SCCoA Member #1826
Riding jack stands.
Old 01-18-2010, 11:09 PM
it feels fine once its warmed up.. Takes WOT with no feeling of it holding back..if i give it a little bit of gas it will stay running, and once i let off it will die...I just picked this car up, but befor i got i, it had been sitting for a few years with a bad fuel pump...Also, with MAF unplugged the car idled decently, but that may just becasue it raised the idle up.. ?
I will throw some injector cleaner in there, couldnt hurt..
Old 01-18-2010, 11:35 PM
XR7 Dave's Avatar
XR7 Dave XR7 Dave is online now
ask questions-get beat up
SCCoA Member #: 1508
Clean your MAF.
Then look for vacuum leaks. Adaptive will correct for a vacuum leak but it can't do anything when the car is open loop.
__________________
Email me here.
  #5
Old 01-18-2010, 11:52 PM
the-big-e's Avatar
the-big-e the-big-e is offline
You can't fix stupid
SCCoA Member #: 2502
Have you put fresh fuel in, or are you still running with the old fuel in the tank....
__________________
Flying is the 2nd greatest thrill known to man. Landing is the first !!!!
Every day, I set a personal record for consecutive days I have remained alive!
If you cut a crumb in half, you don't get two half crumbs, you get two crumbs
Doesn't this violate some law of physics?
  #6
Old 01-19-2010, 12:00 AM
the tank was empty when I dropped it for the pump. It now has fresh fuel in it..it had run very low/out after the initial few gals i put in from moving it in and outa the garage for a while playing with the other cars...Idk if running it low had anything to do with this but its a fresh filter and I cant see how the car running better warm would have to do with a filter. But im open to anything at this point.
the IC tubes are sealed with teflon gaskets and when its running right, the vac is right where it should be....
  #7
Old 01-19-2010, 01:11 AM
David Neibert's Avatar
David Neibert David Neibert is offline
Still loves the Cobra Rs
SCCoA Member #: 858
Get some carb cleaner and spray all the IC tube connections and any other part of the intake system after the TB while it's idling. You will hear the motor rev up when it sucks in the carb cleaner. Doesn't take much of a leak to make it run bad. Gauge can still be showing 20 inches of vacuum with a leak so big you can't keep the motor running, so don't let that fool you.
__________________
91 SC AOD 4.2..2.3 Whipple........10.92 @ 126.70
93 SC AOD 347 Turbo.................10.04 @ 138.99
  #8
Old 01-19-2010, 12:49 PM
thunderkid84 thunderkid84 is offline
trying for 300 hp
SCCoA Member #: 3137
Send a message via AIM to thunderkid84 Send a message via Yahoo to thunderkid84
Put a code scannner on it and also do a cylinder balance test.
Reply
Thread Tools
Rate This Thread:
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Forum Jump
Rough and lean cold idle condition rzimmerl Technical Forum 7 07-01-2009 03:15 PM
UPDATE 5/03 on Pg 4 Cold start-crap idle/Warm start-great idle thunderkid84 Technical Forum 67 05-11-2009 07:53 PM
Cold Start rough idle scpride Technical Forum 0 04-08-2009 08:36 PM
Crappy idle when cold Geevaaa9112 Technical Forum 4 04-10-2006 02:46 PM
Cold Start Idle Question WRGoudy Technical Forum 6 02-18-2004 05:08 PM
