Go Back   Super Coupe Club of America Forums > General SCCoA Forums > Non Technical Forum
User Name
Password
Reply
Old 03-25-2010, 01:53 PM
Toms-SC's Avatar
Toms-SC Toms-SC is offline
-6AN Fuelrail Upgrade
Hey all,
Has anybody successfully upgraded their fuel rails to 6AN? You can buy the material for fairly cheap, $30~ for 3 feet.
Thanks
http://cgi.ebay.com/ebaymotors/Dash-...item2e9dadbb78
Old 03-25-2010, 02:06 PM
Roadhawg Roadhawg is offline
I thought about it, but the step drill bit is exspensive.
http://rossmachineracing.com/injectortool.html
Old 03-25-2010, 02:16 PM
rzimmerl's Avatar
rzimmerl rzimmerl is offline
Send a message via AIM to rzimmerl
I believe there are few people with billet rails. Would be just a matter of getting the correct injector angles drilled into the rail with the special tool.
Another question is what kind of fitting to use on the stock fuel pump hat to adapt to AN?
__________________
1990 SC AOD 1.7 AR
11.676 @ 121.35 mph
Old 03-25-2010, 05:31 PM
David Neibert's Avatar
David Neibert David Neibert is offline
SCCoA Admin
Please keep in mind that Chris Wise made over 500 rwhp thru a non locking C4 on a stingy dyno at the Shootout with stock rail and stock fuel lines.
__________________
91 SC AOD 4.2..2.3 Whipple........10.92 @ 126.70
93 SC AOD 347 Turbo.................10.04 @ 138.99
  #5
Old 03-25-2010, 05:41 PM
ricardoa1's Avatar
ricardoa1 ricardoa1 is online now
Quote:
Does that car utilize more fuel then lets say your car David? SC sucks up HP to make HP. You brought it up in the other thread.
__________________
1994 Supercoupe 5spd Custom Modded. 2010 Shootout-Best Custom Award-415WHP off the bottle-12.2535 @112.18 off the bottle. Best HP to date 445whp Best TQ to date 516ft/lbs Modified with the 1% $$
1990 35th 5spd 2011 Carlisle 1st place class winner. 12.9@108MPH 1.9/60fts Modified with the 99% $$
2 SCs 12sec club member.
  #6
Old 03-25-2010, 06:31 PM
Toms-SC's Avatar
Quote:
Can anybody with this speak up please?
  #7
Old 03-25-2010, 06:34 PM
Toms-SC's Avatar
Its expensive but you don't do it as a one off. Make 10 for the rest of the community to enjoy.
  #8
Old 03-25-2010, 11:50 PM
SCCoA Admin
Quote:
Probably has more capacity, because it has bigger injectors (96# low imp I think) and doesn't need to operate at such high pressures. With the turbo the biggest advantage he enjoys is not having to pull power off the crank to spin the blower. That said, it's still not a free lunch because the exhaust restrictions on a turbo motor also cause a reduction in power, but usually it's only about 30% of what a blower consumes.
PS: Dave Dalke tuned the car, so he can probably provide the fuel consumption info.
__________________
  #9
Old 03-26-2010, 12:17 AM
SCCoA Admin
Quote:
Tom,
Here's a picture of the ones on my car.
They were supplied by a member named Jerrod...here is another style he made.
This is his user profile.
http://www.sccoa.com/forums/member.php?u=388
__________________
  #10
Old 03-26-2010, 02:11 AM
XxSlowpokexX's Avatar
XxSlowpokexX XxSlowpokexX is offline
Send a message via AIM to XxSlowpokexX
I say go big or go home..#8!!!! I have the same ones David has..Very nice
__________________
1994 5 speed-Who needs a MAF anyways!
0 RWHP--0RWT
0 @ 0mph
  #11
Old 03-26-2010, 12:06 PM
90blkbrd's Avatar
90blkbrd 90blkbrd is offline
$30 for 3 feet of rail. I would think that would be enough to build both rails for a SC.
David. What did your fuel rail cost you when you got yours?
If a M90 is ~70-100 hp that would put a turbo at ~21-30. I really thought a turbo's parasitic loss was negligible, as in less than 10.
  #12
Old 03-26-2010, 01:06 PM
SCCoA Admin
I don't remember the exact price, but I think it was around $150-200 for the set.
__________________
  #13
Old 03-26-2010, 01:50 PM
frdlvr30 frdlvr30 is offline
Im sure it requires atleast 20% more fuel to make the same amount of horse power as a turbo car, due to the parasidic drag of the blower. I doubt that you guy are maxing the factory rail out yet. But, for a few hundred bucks the added insurance is surely worth it...IMHO. That being said, have any of you ever had just the engine dyno'd? Is that a possibility or do those with engine dyno's only do so for the ones that they build?
  #14
Old 03-26-2010, 02:19 PM
Toms-SC's Avatar
David,
Is your system still return or is it now return-less?
  #15
Old 03-26-2010, 02:23 PM
SCCoA Admin
David,
Yes, it's a return style system. I can't imagine why anyone would want a returnless system.
__________________
Reply
Thread Tools
Rate This Thread:
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Forum Jump
rear brake upgrade question hellakornhaus Technical Forum 5 07-28-2005 12:59 PM
Replacing Injectors should I upgrade? ERamos Technical Forum 1 05-19-2005 12:13 PM
What size gears should I upgrade to? blkthndr FAQ Forum 0 10-28-2002 07:09 PM
